Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
10-08-2020, 16:46 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | Jkm-lx1 huawei logo stuck ..only fastboot mode...no recovery or upgrade mode using testpoint i used sigmakey and loaded fastboot.... SigmaKey 2.39.02b2 HiSi: Load FastBoot HUAWEI USB COM 1.0 (COM224), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 2014-12-05, USB\VID_12D1&PID_3609&REV_0100 Cancelled --------- 2020-10-08 16:20:22 --------- SigmaKey 2.39.02b2 HiSi: Load FastBoot HUAWEI USB COM 1.0 (COM224), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 2014-12-05, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 710 Phone model: JKM-LX1 Version: JKM-LX1 9.1.0.309(C185E2R2P1) Sending boot...Done then after that flash in chimera Repair recovery Checking if factory challenge needed... Already unlocked. Extracting firmware Processing CURVER. Processing VERLIST. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing VBMETA. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing CACHE. Processing SYSTEM. Processing CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing HISEE_FS. Processing VENDOR. Processing VERSION. Processing ODM. Processing PRODUCT. Processing PREAS. Processing PREAVS. Processing USERDATA. Processing PRELOAD. Processing ERECOVERY_KERNEL. Processing ERECOVERY_VENDOR. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VBMETA. Processing PATCH. Pre-processing image files Flashing image files Flashing ptable Flashing xloader Flashing fastboot Flashing dts Flashing dto Flashing vector Flashing fw_lpm3 Flashing hhee Flashing teeos Flashing trustfirmware Flashing sensorhub Flashing fw_hifi Flashing kernel Flashing vbmeta Flashing modemnvm_update Flashing modemnvm_cust Flashing recovery_ramdisk Flashing recovery_vendor Flashing recovery_vbmeta Flashing cust Flashing isp_firmware Flashing modem_fw Flashing hisee_img Flashing hisee_fs Flashing version Flashing odm Flashing preavs Flashing preload Flashing erecovery_kernel Flashing erecovery_vendor Flashing erecovery_ramdisk Flashing erecovery_vbmeta Flashing patch Rebooting phone to USB update mode Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. The procedure has been canceled. Finished at local time: [10.08.20 16:36:41] WorkID: 110512522 but cud not put the phone in upgrade mode...so got o cancel... Report Post Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message |
10-08-2020, 19:27 | #2 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | why u need chimera? load fastboot flash in fastboot stock match to phone and then reflash in upgrade to better help load fastboot and read info, post here also post what firmware u write |
The Following User Says Thank You to kikas112 For This Useful Post: |
10-24-2020, 07:07 | #3 (permalink) | |
No Life Poster Join Date: Jul 2016 Location: Gods.On.Country
Member: 2602890 Status: Offline Sonork: NOTINSTALLED Thanks Meter: 230 | Quote:
Reading info.....OK Device Model: JKM-LX1 Device Firmware: :JKM-LX1 9.1.0.256(C185E2R2P1) Base Firmware: :JKM-LGRP2-OVS 9.1.0.256 Custom Firmware: :JKM-LX1-CUST 9.1.0.2(C185) Preload Firmware: :JKM-LX1-PRELOAD 9.1.0.1(C185R2) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Operation {Read info} ID: D037DC71BCA3CBF0 Elapsed time 00:00 -- Version 3.5.0 flashed same version Jackman-L21 9.1.0.256(C185E2R5P1T8)_Firmware_EMUI9.1.0_05015NW L flashed with many differnt versions but not going to upgrade mode, logo only , | |
10-28-2020, 11:19 | #4 (permalink) |
No Life Poster Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Offline Thanks Meter: 772 | Just use latest sigmakey version v2.39.04 and flash with board firmware with testpoint then phone back to life and then flash with stock firmware to it, then write certyficate if got backup or from other phone if not have and all will be repaired. |
11-06-2020, 04:29 | #6 (permalink) |
Freak Poster Join Date: Jun 2016 Location: South Africa/Dubai AnyWhere : Age: 29
Member: 2580629 Status: Offline Thanks Meter: 104 | Hi Quote: sigma chimera Or flash board firmware offcial Tool if your probilem Solved Then Fine If not Then PM.. |
11-06-2020, 07:04 | #7 (permalink) |
Member: 1591394 Status: Offline Thanks Meter: 552 | Stop nonsense with that boards, after many ppl lose imei, about this case load fastboot by sigma and flash in fastboot, stock must match to phone and batery charged, in this phone MMC like go to Die Wysłane z mojego moto g(6) play przy użyciu Tapatalka |
