Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
06-24-2020, 14:37 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | LDN-L01 eMMC Repartition !! Without Dump File !! The Set is Successfully Revived You Need Professional JTAG Box, also backup security area for network (How to take backup of network security area by easy jtag v2....???) I' have used easy JTAG for create security / Repartitions eMMC / restore security area data. Code: eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2141 mV CMD Active Level: 2524 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_3704AE5B_20200622_214644.extcsd EMMC Init completed. Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2133 mV CMD Active Level: 2717 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_3704AE5B_20200622_214724.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Operation: Read by vendor... Destination dir: C:\Users\hp\Downloads\LDN-L01\ldn-l01\ Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2131 mV CMD Active Level: 2717 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_3704AE5B_20200622_215250.extcsd EMMC Init completed. Backup partition: 8xxx_msimage Address: 000000004400, size: 000000000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 0.00 Kb/s 8xxx image is blank. Skipped XML-file created successfully Backup partition: PrimaryGPT Address: 000000000000, size: 000000004400 GPTHeader is valid Partition name: fsg Address: 000003180000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 475.00 Kb/s Partition name: modemst1 Address: 000008400000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 474.82 Kb/s Partition name: modemst2 Address: 000008800000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 474.49 Kb/s Partition name: persist Address: 000028000000, size: 000002000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 474.09 Kb/s All done time: [00:01:37:892] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2131 mV CMD Active Level: 2717 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_3704AE5B_20200622_215821.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Successfully Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2133 mV CMD Active Level: 2717 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_3704AE5B_20200622_215835.extcsd EMMC Init completed. This operation is only performed for the Samsung eMMC Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2132 mV CMD Active Level: 2718 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_3704AE5B_20200622_215843.extcsd EMMC Init completed. This operation is only performed for the Samsung eMMC Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2131 mV CMD Active Level: 2718 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_3704AE5B_20200622_215907.extcsd EMMC Init completed. Operation: Reading GP sizes from ExtCSD backup Filename: HAG4a2_3704AE5B_20200622_214644.extcsd Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2133 mV CMD Active Level: 2717 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_3704AE5B_20200622_220002.extcsd EMMC Init completed. Operation: Changing GP sizes (test mode) ... GP1 size: 0 MB , WR_REL: 1 , ENH 1 GP2 size: 0 MB , WR_REL: 1 , ENH 1 GP3 size: 0 MB , WR_REL: 1 , ENH 1 GP4 size: 0 MB , WR_REL: 1 , ENH 1 Zero sizes. This may damage your eMMC Do you want to continue? Successfully Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to cancel the changes Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2133 mV CMD Active Level: 2685 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_3704AE5B_20200622_220020.extcsd EMMC Init completed. Operation: Changing GP sizes (final write) ... GP1 size: 0 MB , WR_REL: 1 , ENH 1 GP2 size: 0 MB , WR_REL: 1 , ENH 1 GP3 size: 0 MB , WR_REL: 1 , ENH 1 GP4 size: 0 MB , WR_REL: 1 , ENH 1 Zero sizes. This may damage your eMMC Do you want to continue? Successfully Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize operation After reconnect, make sure that the size of ROM1 has been changed. Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2132 mV CMD Active Level: 2684 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG4a2_3704AE5B_20200622_220328.extcsd EMMC Init completed. Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2132 mV CMD Active Level: 2717 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG4a2_3704AE5B_20200622_220348.extcsd EMMC Init completed. Writing eMMC Register ... Reg: 179 Value: 0x38 Successfully Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2133 mV CMD Active Level: 2718 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG4a2_3704AE5B_20200622_220404.extcsd EMMC Init completed. Filename: HAG4a2_3704AE5B_20200622_214644.extcsd Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2132 mV CMD Active Level: 2717 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG4a2_3704AE5B_20200622_220452.extcsd EMMC Init completed. Opening file: LDN-AL10-BD_1.0.0.37_Download.xml Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2132 mV CMD Active Level: 2719 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG4a2_3704AE5B_20200622_220527.extcsd EMMC Init completed. Opening file: HAG4a2_rawprogram0.xml The size of the last section has been updated Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2131 mV CMD Active Level: 2717 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG4a2_3704AE5B_20200622_220537.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 GPT-partitioning done Partition name: fsg Filename: fsg.bin , Offset: 000003180000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 421.49 KB/s Partition name: modemst1 Filename: modemst1.bin , Offset: 000008400000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 458.43 KB/s Partition name: modemst2 Filename: modemst2.bin , Offset: 000008800000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 457.60 KB/s Partition name: persist Filename: persist.bin , Offset: 000028000000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 459.54 KB/s Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [00:02:17:479] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 MHz CMD Pullup Level: 2130 mV CMD Active Level: 2717 mV EMMC Device Information : EMMC CID: 90014A484147346132D43704AE5B4541 EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 3704AE5B , rev. 0xD4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 3574 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG4a2_3704AE5B_20200622_220839.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000004400 - 000000084400], size: 000000080000 (512. KB) Partition: rpm, [000000084400 - 000000104400], size: 000000080000 (512. KB) Partition: tz, [000000104400 - 000000304400], size: 000000200000 (2.00 MB) Partition: devcfg, [000000304400 - 000000344400], size: 000000040000 (256. KB) Partition: dsp, [000000344400 - 000001344400], size: 000001000000 (16.0 MB) Partition: keystore, [000001344400 - 0000013C4400], size: 000000080000 (512. KB) Partition: frp, [0000013C4400 - 000001444400], size: 000000080000 (512. KB) Partition: mota, [000001444400 - 0000014C4400], size: 000000080000 (512. KB) Partition: dip, [0000014C4400 - 0000015C4400], size: 000000100000 (1.00 MB) Partition: syscfg, [0000015C4400 - 000001644400], size: 000000080000 (512. KB) Partition: lksecapp, [000001644400 - 000001664400], size: 000000020000 (128. KB) Partition: apdp, [000001664400 - 0000016A4400], size: 000000040000 (256. KB) Partition: msadp, [0000016A4400 - 0000016E4400], size: 000000040000 (256. KB) Partition: dpo, [0000016E4400 - 0000016E6400], size: 000000002000 (8.00 KB) Partition: fsc, [0000016E6400 - 0000016E6800], size: 000000000400 (1.00 KB) Partition: ssd, [0000016E6800 - 0000016E8800], size: 000000002000 (8.00 KB) Partition: bootfail_info, [0000016E8800 - 0000018E8800], size: 000000200000 (2.00 MB) Partition: pad0, [0000018E8800 - 000002000000], size: 000000717800 (7.09 MB) Partition: aboot, [000002000000 - 000002400000], size: 000000400000 (4.00 MB) Partition: cmnlib, [000002400000 - 000002500000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [000002500000 - 000002600000], size: 000000100000 (1.00 MB) Partition: keymaster, [000002600000 - 000002700000], size: 000000100000 (1.00 MB) Partition: pad1, [000002700000 - 000003180000], size: 000000A80000 (10.5 MB) Partition: fsg, [000003180000 - 000003580000], size: 000000400000 (4.00 MB) Partition: DDR, [000003580000 - 000003588000], size: 000000008000 (32.0 KB) Partition: sec, [000003588000 - 00000358C000], size: 000000004000 (16.0 KB) Partition: devinfo, [00000358C000 - 00000368C000], size: 000000100000 (1.00 MB) Partition: limits, [00000368C000 - 000003694000], size: 000000008000 (32.0 KB) Partition: pad2, [000003694000 - 000004000000], size: 00000096C000 (9.42 MB) Partition: oeminfo, [000004000000 - 000008000000], size: 000004000000 (64.0 MB) Partition: misc, [000008000000 - 000008400000], size: 000000400000 (4.00 MB) Partition: modemst1, [000008400000 - 000008800000], size: 000000400000 (4.00 MB) Partition: modemst2, [000008800000 - 000008C00000], size: 000000400000 (4.00 MB) Partition: rrecord, [000008C00000 - 000009400000], size: 000000800000 (8.00 MB) Partition: nff, [000009400000 - 000009C00000], size: 000000800000 (8.00 MB) Partition: mcfg, [000009C00000 - 00000A000000], size: 000000400000 (4.00 MB) Partition: modem, [00000A000000 - 000010000000], size: 000006000000 (96.0 MB) Partition: erecovery_kernel, [000010000000 - 000013800000], size: 000003800000 (56.0 MB) Partition: erecovery_ramdisk, [000013800000 - 000015800000], size: 000002000000 (32.0 MB) Partition: erecovery_vendor, [000015800000 - 000016800000], size: 000001000000 (16.0 MB) Partition: kernel, [000016800000 - 00001A000000], size: 000003800000 (56.0 MB) Partition: ramdisk, [00001A000000 - 00001B000000], size: 000001000000 (16.0 MB) Partition: recovery_ramdisk, [00001B000000 - 00001D000000], size: 000002000000 (32.0 MB) Partition: recovery_vendor, [00001D000000 - 00001E000000], size: 000001000000 (16.0 MB) Partition: cache, [00001E000000 - 000026000000], size: 000008000000 (128. MB) Partition: odm, [000026000000 - 000028000000], size: 000002000000 (32.0 MB) Partition: persist, [000028000000 - 00002A000000], size: 000002000000 (32.0 MB) Partition: log, [00002A000000 - 00002E000000], size: 000004000000 (64.0 MB) Partition: patch, [00002E000000 - 000030000000], size: 000002000000 (32.0 MB) Partition: version, [000030000000 - 000032000000], size: 000002000000 (32.0 MB) Partition: vendor, [000032000000 - 000058000000], size: 000026000000 (608. MB) Partition: product, [000058000000 - 000064000000], size: 00000C000000 (192. MB) Partition: cust, [000064000000 - 000070000000], size: 00000C000000 (192. MB) Partition: system, [000070000000 - 00010E000000], size: 00009E000000 (2.47 GB) Partition: userdata, [00010E000000 - 0003AB3FBE00], size: 00029D3FBE00 (10.4 GB) GPT header successfully parsed Step 2, When Your 1'st step Job has been done, Your need another professional tools which one supported APP file flashing via EDL mode. for this operation i have Used EFT Pro. Code: Checking EDL port.....Detected {COM2 } Decrypting package.....OK Inflating package.....OK Preparing.....OK Loading loader.....OK Sending files.....OK Resetting device.....OK Waiting for fastboot device.....OK Reading info.....OK Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT Preparing.....OK Writing partition info table.....OK Flashing [RPM].....OK Flashing [TZ].....OK Flashing [SBL1].....OK Flashing [APDP].....OK Flashing [MSADP].....OK Flashing [MODEM].....OK Flashing [DSP].....OK Flashing [CMNLIB].....OK Flashing [KEYMASTER].....OK Flashing [CMNLIB64].....OK Flashing [DEVCFG].....OK Flashing [LKSECAPP].....OK Flashing [ABOOT].....OK Flashing [KERNEL].....OK Flashing [RAMDISK].....OK Flashing [RECOVERY_RAMDISK].....OK Flashing [RECOVERY_VENDOR].....OK Flashing [ERECOVERY_KERNEL].....OK Flashing [ERECOVERY_RAMDISK].....OK Flashing [ERECOVERY_VENDOR].....OK Flashing [SYSTEM].....OK Flashing [CACHE].....OK Flashing [ODM].....OK Flashing [VENDOR].....OK Flashing [PRODUCT].....OK Flashing [USERDATA].....OK Flashing [CUST].....OK Flashing [VERSION].....OK Flashing [USERDATA].....OK Rebooting device.....OK Operation {UnBrick Device} ID: AB568FA372086BA6 Elapsed time 09:00 -- Version 3.1.1 You can use this firmware, https://forum.gsmhosting.com/vbb/f92...185d1-2563700/ Step 3, When your phone successfully flash via EDL mode after your phone will be RUN normally. Now you need to repair IMEI & another all security area for this operation i have used Hcu from DC Unlocker team. Code: Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode Repair 2020-06-24 00:16:59.705 Autodetect COM port and phone type start! 2020-06-24 00:17:00.859 Found COM port: COM78 2020-06-24 00:17:00.859 Found phone type: Huawei Android phone (Qualcomm CPU) New IMEI 1 : 863066034560646 New Bluetooth MAC : B0:89:00:25:37:BD New WiFi MAC : B0:89:00:25:42:4A New SN : FUH7N16928002125 New PCB SN : 7N3RUP16A7062384 New Vendor : hw New Country : meafnaf New Model : LND-L01 2020-06-24 00:17:01.031 Open COM port COM78 (DBAdapter Reserved Interface (COM78))... 2020-06-24 00:17:01.265 Connecting to server... 2020-06-24 00:17:02.045 Connected! 2020-06-24 00:17:12.387 Read phone secure info... 2020-06-24 00:17:12.606 Read phone basic info... 2020-06-24 00:17:12.746 Phone info data backup saved to file D:\Software\DC unlocker\HCU_358\Backup\20200624_001712_863066034560646.BAK 2020-06-24 00:17:13.261 Repairing PCB SN... 2020-06-24 00:17:13.292 Repair PCB SN success! 2020-06-24 00:17:13.292 Calculating phone secure data... 2020-06-24 00:17:13.729 Calculate phone secure success! 2020-06-24 00:17:13.729 Writing phone secure data... 2020-06-24 00:17:13.901 Writing phone secure data success! 2020-06-24 00:17:14.228 Repairing Vendor and Country... 2020-06-24 00:17:14.228 Calculating phone secure data... 2020-06-24 00:17:14.649 Calculate success! 2020-06-24 00:17:14.665 Writing phone secure data... 2020-06-24 00:17:14.681 Writing phone secure data success! 2020-06-24 00:17:15.039 Repairing Vendor and Country success! 2020-06-24 00:17:15.039 Writing model... 2020-06-24 00:17:15.055 Write model success! 2020-06-24 00:17:15.055 Read from server... 2020-06-24 00:17:15.383 Read from server success! 2020-06-24 00:17:15.398 Repairing SN... 2020-06-24 00:17:15.414 Repair SN success! 2020-06-24 00:17:16.085 Finished!
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 06-24-2020 at 14:45. |
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
