Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA Box
Old 07-27-2017, 22:24   #1 (permalink)
Hua Supporter's Avatar
Member: 2179353
Thanks Meter: 17,022
**************hmi(xiaomi on hqt)Tool Manuals and Videos************
HOW TO REPAIR IMEI XIAOMI QUALCOMM PHONES BY HMI?
*Backup phone original QCN before Repair IMEI by QPST Free Tool*
0. Backup from dump or securtiy with hmi before repair imei
1. Power on the phone and enable "USB Debugging" option
2. Connect phone to pc via USB cables(EDL MODE OR FASTBOOT MODE)
3. Open hqt.EXE and Goto Service Tab
4. GOTO XIAOMI TAB and Press Erase Imei(fastboot mode need unlock bootloader) and then Reset Factory phone(Manually on setting)
5. Press *#06# and Check IMEI IS INVALID
6. Dial(*#*#717717#*#*) For Enable Qualcomm Diag port
7. OPEN AHT/Select Diag Port on Setting
8. GOTO QUALCOMM/XIAOMI TAB Enter Imei1 or 2 and Press Repair
9. Goto Phone Setting and Press Factory Reset
10. Restore Qcn on Phone By QPST FREE TOOL
11. PRESS FACTORY RESET AGAIN
12.DONE
The Following 8 Users Say Thank You to Hua Supporter For This Useful Post:
Old 07-27-2017, 23:09   #2 (permalink)
Member: 2179353
How to Remove MI ACCOUNT BY HMI?
Note :
Remove mi account solutions on hmi is not supported by china or developer roms
1. Enter Phone To Fastboot(NEED UNLOCK BOOTLOADER) or EDL mode (NEED 9008 PORT)
2. Open HMI.EXE and Goto Service Tab
3. Press Reset Mi Account and select Method 1 OR 2 OR 3
-If phone locked still or Wifi not working or Hang on Logo, please do UNLOCK SCREEN LOCK(sideload mode if phone dont have Wipe on recovery)or Write Dump or write fix patch wifi file to fix problem.
-If phone auto relock after online, please use "method4" or write full dump on phone to fix problem.
1. Enter Phone To EDL mode (NEED 9008 PORT)
4. Connect Phone to sideload and then press wipe by hmi tool
5.done
new method
write special free file on phone and make a new account after reset
-just write persist file
http://forum.gsmhosting.com/vbb/f930...count-2255422/
http://forum.gsmhosting.com/vbb/f930...hones-2256195/
you need donwgrade to miui 8 if phone is new security
about remove mi account on new miui security
http://forum.gsmhosting.com/vbb/f930...wares-2267237/
One Click Solution Not available For new Miui Solution.at the moment.
You need to flash with old firmware(miui7 or 8 or developer)ticked with clean all and lock. after that register new mi account.
The Following 7 Users Say Thank You to Hua Supporter For This Useful Post:
Old 07-27-2017, 23:10   #3 (permalink)
Member: 2179353
How Enable Diagnostic Port on Xiaomi Phones?
In Dial Pad enter this combination *#*#717717#*#*
if Not Work enter this combination *#*#13491#*#* in usb config setting pop-up window Select DIAG,SERIAL_SMD,RMNET_IPA,ADB
The Following 4 Users Say Thank You to Hua Supporter For This Useful Post:
Old 07-27-2017, 23:10   #4 (permalink)
Member: 2179353
How Dump ROM from Xiaomi Phone (EDL MODE)
in Main Tool Window in Repair TAB Select Dump Option
Connect Phone in EDL Mode
Press List Partitions Button and Wait Until Procedure Done
IF You Want FULL DUMP Then Press On Select All if not Select each Partitions you want to dump and deselect other(s)
Press Dump Button
The Following 2 Users Say Thank You to Hua Supporter For This Useful Post:
Old 07-27-2017, 23:11   #5 (permalink)
Member: 2179353
How Flash Xiaomi Phone with Factory Flash file (EDL MODE)
First Make sure Your Flash file Package is FASTBOOT Update Version
If You Dont Have FASTBOOT Update file Package you can Download your Phone Firmware from HERE
Extract 'image' Folder in Flash File Package to your Favorite Location
Press F Button in Main Tool Windows in TAB Flash
Select rawproram0.xml and immediatly after that select patch0.xml in image folder you extract on few step above
Press Flash Button
The Following 3 Users Say Thank You to Hua Supporter For This Useful Post:
Old 07-27-2017, 23:11   #6 (permalink)
Member: 2179353
How Boot Phone in EDL Mode with EDL(DEEP) Cable
Turn off Phone if its on
Press Button on Cable and Conect it to Phone
IF YOUR PHONE SUPPORT EDL CABLE IT MUST STAY OFF AND WINDOWS DETECT PHONE IN EDL MODE
IF YOUR PHONE NOT SUPPORT EDL CABLE IT JUST TURN ON IN THIS CASE IGNORE EDL CABLE SOLUTION
if Your Windows Detect your Phone in EDL Mode:
If You dont install EDL Driver before it must detect your phone as QHSUSB_BULK
in this case Install Driver You Can Found it in 'C:\AHT2\Driver\QDLoader' the install exe file in this folder
If You Installed EDL Driver Before it must Detect as Qualcomm HS-USB QDLoader 9008 (COMX) [X= COM Number]
Select Qualcomm HS-USB QDLoader 9008 (COMX) Port in Select Port Section in Main Window tool
Old 07-27-2017, 23:12   #7 (permalink)
Member: 2179353
How Boot Phone in EDL Mode with TESTPOINT
Disassemble Phone (Not need to Full Disassemlbe in most case)
Find your Phone TESTPOINT you can Download some Xiaomi Phones TESTPOINT from Here Archive Password: asansam
Connect TESTPOINTS with Piece of wire or metal tweezer then Connect USB Cable to Phone.
if Your TESTPOINT connection was correct now Your Windows Must Detect your Phone in EDL Mode:
Disconnect TESTPOINT Connection (IT'S IMPORTANT)
Old 07-27-2017, 23:12   #8 (permalink)
Member: 2179353
How Boot Phones in FASTBOOT with Phone Buttons
Press Volume Down and Power and wait until you see FASTBOOT Screen
Connect USB Cable to Phone and install Needed Driver.
Old 07-27-2017, 23:12   #9 (permalink)
Member: 2179353
How Enable USB Debugging in Xiaomi Phones
First goto Settings then About Phone.
Tap 7 times on MIUI version.
Return Back to Settings in System & Device goto Additional Settings the goto Developer options and Enable USB Debugging
Old 07-27-2017, 23:16   #10 (permalink)
Member: 2179353
How Boot Phones in Sideload mode with Phone Buttons
Press Volume Up and Power and wait until you see recovery Screen
Select Recovery for enter to sideload mode
Old 07-27-2017, 23:20   #11 (permalink)
Member: 2179353
How Boot Phones in Sideload mode with hmi tool
Turn on Phone
Enable Usb debuggin
Select Reboot to recovery
done
Old 07-27-2017, 23:23   #12 (permalink)
Member: 2179353
How Boot Phone in EDL Mode without edl cable or test point?
adb method
Turn on the phone
Enable Usb debugging
open hmi.exe tool
select EDL MODE (ADB) on bootmode
Press Repair
Connect Cable to phone
done
Old 07-27-2017, 23:24   #13 (permalink)
Member: 2179353
fastboot method
open hmi.exe tool
select EDL MODE 1 or 2 on bootmode
Press Repair
done
Old 07-27-2017, 23:26   #14 (permalink)
Member: 2179353
How Boot Phones in EDL mode from recovery menu
Select Download for enter to edl mode
Old 07-27-2017, 23:29   #15 (permalink)
Member: 2179353
How to Read Pattern BY HMI?
3. Press read pattern adn wait for show screen codes
-mi5 and mi6 is not supported
Page generated in 0.23547 seconds with 8 queries
