10-25-2017, 18:05 | #1 (permalink) |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Send Request Here if Need Unlock screen Lock File For Samsung Phones what need for request ? Full model Build Number Check on Download Mode FRP : OFF Tnx BR HUA TEAM Last edited by Hua Supporter; 10-26-2017 at 10:36. |
The Following 3 Users Say Thank You to Hua Supporter For This Useful Post: |
10-26-2017, 09:49 | #3 (permalink) | |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Quote:
https://www.4shared.com/file/in-m8Op...reen_lock.html | |
10-26-2017, 10:26 | #4 (permalink) | |
Cheater -Don't Deal with him- Join Date: Oct 2012 Location: India
Member: 1819112 Status: Offline Sonork: 100.1792895 Thanks Meter: 23 | Operation Failed Quote: Prepairing Needed Data... OK Searching For Phone [SAMSUNG USB PORT]... OK Phone Found on COM115 Initialize Phone ... OK Prepairing... OK Reading PIT Data ...OK Analizing PIT Entries... OK Pit Entry Num: 27 Writing Special File... Uploading 'DATA_1'... Fail! | |
10-26-2017, 10:34 | #5 (permalink) | |
SOLUTION : RESET FRP FIRST. | |
10-29-2017, 10:02 | #7 (permalink) | |
-Full model -Build Number -Check on Download Mode FRP : OFF https://www.4shared.com/file/ZMYKIXz...reen_lock.html | |
10-30-2017, 20:56 | #10 (permalink) |
Freak Poster Join Date: Aug 2006 Location: gabon, oyem
Member: 327704 Status: Offline Thanks Meter: 84 | when i try to Extract Boot Files For Reset Screen Lock and flash. i get UDC START secure check fail :boot here is log Prepairing File... OK Injecting Data... OK Bypassing Security... OK Rebuilding Security... OK Crippling Security Done! Prepairing Needed Data... OK Searching For Phone [SAMSUNG USB PORT]... OK Phone Found on COM7 Initialize Phone ... OK Prepairing... OK Reading PIT Data ...OK Analizing PIT Entries... OK Removing Screen Locks... Uploading 'DATA_1'... OK Resetting... If Your Phone Still Have any Lock Screen, It's New Security and this solution not work! Operation Time: 00:00:44 |
10-30-2017, 21:00 | #11 (permalink) | |
If boot is encrypted, then you can't use this function. sorry i check now.this phone is for 2014, November and dont have patch file boot.img method is for 2016/2017 phones Last edited by Hua Supporter; 10-30-2017 at 22:29. | |
The Following User Says Thank You to Hua Supporter For This Useful Post: |
11-29-2017, 18:41 | #13 (permalink) |
No Life Poster Join Date: Nov 2005 Location: EingneeR
Member: 201469 Status: Offline Sonork: software Thanks Meter: 50 | unlock pattern lock support all samsung 2017 all protect u1,2,3,4 a320f,a720f,a520f,s8,note 8 ..... and special file unlock not show which ver u1 or 2,3,4,5 plz explain or detect special unlocked files with version |
11-29-2017, 21:37 | #14 (permalink) | |
http://forum.gsmhosting.com/vbb/f930...-mode-2266077/ select boot.img same Phone build number | |
12-01-2017, 17:37 | #15 (permalink) |
Member: 201469 Status: Offline Sonork: software Thanks Meter: 50 | reading again trying A320f 7.0 with boot.img and same Phone build number not success and trying special file same not success but success with other tool ?removed lock suggestion do update to remove lock user with recovery.img its successfully its removed systemui.apk reflash phone become ok regards Last edited by Hua Supporter; 12-01-2017 at 20:55. |
