07-25-2019, 21:58 | #2 (permalink) |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | For remove MI use 1.Flash twrp 2.Format DATA press yes 3. Install rom 4. Mount System 5. Goto File manager 6. Goto Setting>Apps and delete Cloudservice .apk 7. Goto Setting>Priv-app detele finddevice.apk 8. Reboot |
The Following User Says Thank You to Hua Supporter For This Useful Post: |
07-25-2019, 23:17 | #3 (permalink) |
Insane Poster Join Date: Dec 2010 Location: Lima-Perú
Member: 1467439 Status: Offline Sonork: Muradin Thanks Meter: 5 | thank you, Hua box support erase imei edl mode for Redmi note 7? I have this problem Searching for Device... OK Prepairing Device on [COM20-Qualcomm HS-USB QDLoader 9008 ]... OK Waiting for Phone ACK... OK Fail! Stop Signal Detected! Procedure Stopped By User Request Connection terminated. Rebooting to Normal Mode... OK Connection terminated. Operation Time: 00:03:28 Searching for Device... OK Prepairing Device on [COM20-Qualcomm HS-USB QDLoader 9008 ]... OK Waiting for Phone ACK... OK Fail! Stop Signal Detected! Procedure Stopped By User Request Connection terminated. Rebooting to Normal Mode... OK Connection terminated. Operation Time: 00:00:55 |
07-26-2019, 07:08 | #4 (permalink) |
Member: 1467439 Status: Offline Sonork: Muradin Thanks Meter: 5 | Searching for Device... OK Prepairing Device on [COM30-Qualcomm HS-USB QDLoader 9008 ]... OK Waiting for Phone ACK... OK Serial Number: 13F85EB3 CPU ID: 0008C0E100000000 | Type: Snapdragon 660 SDM660 SBL Ver: 04000000 OEM Key(PK): A7B8B82545A98ECA23D6E9105FB464568D1B5828264903441B DEF0CD57E3C370 Changing Mode to SAHARA... OK Prepairing... OK -> [000000000000000D][0000000000000000:0000000000000040] Sending Loader... Fail! Stop Signal Detected! Procedure Stopped By User Request Connection terminated. Rebooting to Normal Mode... OK Connection terminated. Operation Time: 00:00:10 |
07-26-2019, 07:42 | #5 (permalink) | |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Quote:
