xiaomi imei REPAIR soloution 2016-10-02 - 17:55:08 : Searching for Phone ...OK 2016-10-02 - 17:55:08 : Preparing Phone on COM4-Qualcomm HS-USB Android DIAG 901D 2016-10-02 - 17:55:11 : Reading Phone Information ... 2016-10-02 - 17:55:11 : Build No : MPSS.DPM.1.0.c7.18-00023-M8916EAAAANUZM-1-all15 2016-10-02 - 17:55:11 : IMEI : 667935023501281 2016-10-02 - 17:55:11 : ESN : 00000000 2016-10-02 - 17:55:11 : Writing IMEI1... OK 2016-10-02 - 17:55:11 : Writing IMEI2... OK 2016-10-02 - 17:55:11 : 2016-10-02 - 17:55:11 : Please Factory Reset Your Phone to complete the operation 2016-10-02 - 17:55:11 : HINT: (Go to Settings > General > Backup > Erese/Factory data reset press 'Reset phone' and 'Erase everything' buttons) 2016-10-02 - 17:55:11 : Stopping ADB Service... OK 2016-10-02 - 17:55:11 : Operation Time: 00:00:03 after full factory reset imei is not repair help hua team ..issue is very old solve this threat |
What is phone model? |
model no is......redmi HM 2LTE-IN |
THIS MODEL IS NOT SUPPORTED BY HUABOX READ QCN AND SEND FOR ME solution for xiaomi phones Quote:
-reset security(lg tab) -check imei is 00000000000000/01 -enable diag port -select diag port -goto unlock/imei tab -enable skip reset security -enter imei1 or imei2 -select method2 -press repair -done -factory reset now Quote:
here is qcn sir this is only requst not thread hua team LG_QCN_1641_02_10-22_02_53 - Download - 4shared - kkabeer khan |
read qcn success 02 - 22:32:21 : For Android 4.x.x and Above: 2016-10-02 - 22:32:21 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2016-10-02 - 22:32:21 : 2- Return to General Tab Tap on Developer Options 2016-10-02 - 22:32:21 : 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone 2016-10-02 - 22:32:21 : 4- Select LG Software on Appeared Pop-up Window 2016-10-02 - 22:32:21 : 5- Hit 'R' Button on Software then Select 'LGE AndroidNet USB Serial Port' 2016-10-02 - 22:32:21 : 2016-10-02 - 22:32:24 : Operation Time: 00:00:02 2016-10-02 - 22:32:26 : Please Select QCN File! 2016-10-02 - 22:32:26 : Operation Time: 00:-01:-03 2016-10-02 - 22:32:28 : Please Select QCN File! 2016-10-02 - 22:32:28 : Operation Time: 00:-01:-05 2016-10-02 - 22:32:31 : Please Select QCN File! 2016-10-02 - 22:32:31 : Operation Time: 00:-01:-07 when i fill up file in hua software lg qcn tab says massage ..failed to Decrypt resource help hua team |
-read security(lg tab) -reset security(lg tab) -check imei is 00000000000000/01 -enable diag port -select diag port -goto unlock/imei tab -enable skip reset security -enter imei1 or imei2 -select method2 -press repair -done -factory reset now problem is not solve plzz help hua team Searching for Phone ...OK Preparing Phone on COM21-Qualcomm HS-USB Diagnostics Reading Phone Information ... Build No : MPSS.DPM.2.0-a8913ba IMEI : 667634091411202 ESN : 00000000 Writing IMEI1... OK Writing IMEI2... OK Please Factory Reset Your Phone to complete the operation HINT: (Go to Settings > General > Backup > Erese/Factory data reset press 'Reset phone' and 'Erase everything' buttons) Operation Time: 00:00:03 |
Xiaomi Mii 4i Read Qcn File plzz Give Me Hua Team And Any One plz plz plz help me thanxxx.... |
this is good phone qcn redmi 2 ..hua team GT-I8262_MPSS.DPM.1.0.c7.18-00021-M8916EAAAANUZM-1-all14_17-2-2016_20-6-12 - Download - 4shared - kkabeer khan |
Xiaomi Mii 4i Read Qcn File plzz Give Me plzzz thanxx |
xiaomi mi2 is possibl repair |
xiaomi redmi note 6 pro, every time i write QCN, corrupts nv data koi plzz edit qcn dalo yaar plzz hai tho solution edit kaise hionge imei origneal tho chad jate hai bt edit kiye hwe qcn chadate hi nv data corapted solution gsm form plzzz |
HOW TO REPAIR IMEI XIAOMI QUALCOMM PHONES BY HUA ? MIUI 9 AND 10 IS NOT SUPPORTED *Backup phone original QCN before Repair IMEI by QPST Free Tool* https://www.4shared.com/rar/g86esMYv...N_BY_QPST.html 0. Backup from dump or securtiy with hmi before repair imei 1. Power on the phone and enable "USB Debugging" option 2. Connect phone to pc via USB cables(EDL MODE OR FASTBOOT MODE) 3. Open hqt.EXE and Goto Service Tab 4. GOTO XIAOMI TAB and Press Erase Imei(fastboot mode need unlock bootloader) and then Reset Factory phone(Manually on setting) 5. Press *#06# and Check IMEI IS INVALID 6. Dial(*#*#717717#*#*) For Enable Qualcomm Diag port 7. OPEN AHT/Select Diag Port on Setting 8. GOTO QUALCOMM/XIAOMI TAB Enter Imei1 or 2 and Press Repair 9. Goto Phone Setting and Press Factory Reset 10. Restore Qcn on Phone By QPST FREE TOOL 11. PRESS FACTORY RESET AGAIN 12.DONE |
