IPHONE 6 draining battery very fast iphone 6 draining battery very fast have change battery but still the same draining the battery very fast what can cause this problem? any solution? |
chage u2 ic it will solve it |
Try to restore the phone. Make sure you backup data first. If it doesn't work, Check the tristar chip. Good luck bro! https://blog.rewatechnology.com/tips...y-replacement/ |
Solutions to iPhone 6 battery draining fast: 1. Monitor Battery Usage. Go to Settings > Battery to find the option and then turn off certain features that consume too much power. 2. Check Charging Accessories. Unmatching charging accessories are very likely to cause damages to your battery, making its life becomes shorter and shorter. 3. Turn Off Background App Refresh. Settings > General > Background App Refresh. 4. Chances are that there is something wrong with your iPhone software. Faced with this, try Joyoshare iPhone system recovery to fix the issue without data loss. 5. If it is the battery itself that causes the issue, go to the Apple store to ask for help. |
basic steps but it could help anybody thanks |
