09-01-2015, 19:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: United Kingdome
Member: 1507640 Status: Offline Thanks Meter: 131 | Iphone error 53 ?? Here i am starting thread regarding error 53 which is common in iphone 6 and 6 plus there are some solution which can sort this error:- 1:-Change long home button flex which attach to LCD after restore it will get success if issue related to this. I fix 10 unit with this solution before. But now this solution not seems to work for all iphone 6 and 6 plus units because i am facing error 53 after fixing home button flex so what is the Fix for this problem please share your experiences here regarding this problem. |
The Following User Says Thank You to mobileboothuk For This Useful Post: |
10-26-2015, 11:30 | #5 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2478118 Status: Offline Thanks Meter: 0 | hi mobileboothuk i have too been searching everywhere for this solution but no luck.. the only thing i can tell you guys is that if there is something wrong with the long flex on the lcd shield you will get the -53 error if this is the case you have the simple fix by just changing the shield and long cable. otherwise its a stupid problem like cable or no good connection to the servers of apple. if you lost your original home button you are screwed.. there is no way to restore the phone with a new homebutton cause its linked to the motherboard. so if you repair a screen and replace a new home button or such you can't update or restore the phone anymore. or it will be bricked. |
