Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 6 / iPhone 6 Plus / iPhone 6S / iPhone 6S Plus
Old 06-17-2020, 12:10   #1 (permalink)
Member: 367404
Exclamation iPhone 6 Plus touch issue
Hello All,
I have a iPhone 6+ which touch screen stopped working after use and after restarting it will start work but stopped again after sometime.
i have tried to clean the screen contacts and also reset the software version but still i m facing the same issue screen touch is not working properly.
Do any one have any solution to clear this iPhone issue.
Kind Regards
Old 06-17-2020, 21:45   #2 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 875
Originally Posted by fact41 View Post
Hello All,
Kind Regards
hi
you should to reball big black ic , chech image
The Following User Says Thank You to orx For This Useful Post:
Old 06-21-2020, 11:21   #3 (permalink)
Member: 2136572
Sonork: 100.1653162
Thanks Meter: 41
follow the steps below to solve the problem, I copied them from SFS web app.
go to https://www.tapticengines.com/engine/sfs/sfs-online to see the solution image.
step_1
1- Try another LCD (orginal ) or tested one, and test if you still have the same problem.
step_2
2- Check the touch connector ( J2401 ) if it's cracked or damaged, resolder or replace.
step_3
3- Check ( U2401 ) the touch controller IC [ CUMULUS ] if it's damaged or cracked, resolder or replace.
step_4
4- Check ( U2402 ) the touch controller IC [ MESON A1 ] if it's damaged or cracked, resolder or replace. Check ( L2401 ) IF it's cracked or damaged, resolder or replace.
step_5
5- Check ( R2411, R2412, R2433, R2495 ) if cracked or damaged, resolder or replace. Test the connection between ( R2411, R2412, R2433, R2495) and the ( J2401 ) connector as the Picture shows, if there is any missing one reconnect it using a jumper wire.
step_6
6- Check ( C2432, C2433 ) if cracked or damaged, resolder or replace. The voltage on these capacitors must be: (C2432 = 1.8 V ). (C2433 = 1.2 V ).
step_7
7- Check ( C2414, C1577, C1504, C2409 ) if it's cracked or damaged, resolder or replace. Test the voltage on ( C2414, C2409 ) if it's not ( 5.7 V ) , resolder or replace U1501, then test if still not ( 5.7 V ) , Test the voltage on ( C1547, L1519 ) must be ( Main VCC ) if not Check the power IC U1202.
step_8
8- Check ( C2402, C1541 ) if it's cracked or damaged, resolder or replace. Test the voltage on ( C2402, C1541 ) if it's not ( 5.1 V ) , resolder or replace U1501, then test if still not ( 5.1 V ) , Test the voltage on ( C1547, L1519 ) must be ( Main VCC ) if not Check the power IC U1202.
step_9
9- Check ( C2403 ) if it's damaged or cracked, resolder or replace. Test the voltage on ( C2403 ) if it's not ( 1.8 V ) Check the power IC ( U1202 ).
step_10
10- Check ( C2415 ) if it's damaged or cracked, resolder or replace. Test the voltage on ( C2415 ) if it's not ( 1.8 V ) Check the power IC ( U1202 ).
step_11
11- Check ( C2490, FL2486, C2405, C2408, C2441 ) if cracked or damaged, resolder or replace. the voltage on ( FL2486 = -12.0 v ).
step_12
12- Check ( C2404, C2440 ) if it's cracked or damaged, resolder or replace. The voltage on ( C2404 = -12.0 V ). The voltage on ( C2440 = 13.5 V ).
step_13
13- Check ( C2436, C2437 ) if it's cracked or damaged, resolder or replace.
step_14
14- Check ( C2410, C2411 ) if it's cracked or damaged, resolder or replace. The voltage on ( C2410 = 14.0 V ). The voltage on ( C2411 = -14.0 V ).
The Following 2 Users Say Thank You to AYSER For This Useful Post:
Old 07-22-2020, 10:20   #4 (permalink)
Member: 2730637
Thanks Meter: 102
Hope the repair guide below can give you a hint.
https://blog.rewatechnology.com/diag...ouch-id-issue/
https://blog.rewatechnology.com/repa...n-not-working/
Old 07-25-2020, 15:51   #5 (permalink)
Member: 367404
Originally Posted by orx View Post
hi
Attachment 375918
Bro what if i heat these IC with some paste? and the IC will take its place again?
Old 08-10-2020, 14:22   #6 (permalink)
Member: 1429499
Thanks Meter: 28
Bro no voltage this cap and coil how defect parts I change U2402 and u2401
C2404 = -12.0 V FL2486 = -12.0 v
Plz help.
Old 08-10-2020, 15:59   #7 (permalink)
Member: 2963882
Thanks Meter: 2
This is known issue with 6Plus aka touch disease. First, reball Meson(U2402), if the problem persist, jump M1 pad, the problem is micro damage.
The Following 2 Users Say Thank You to rhwks For This Useful Post:
Old 08-18-2020, 07:06   #8 (permalink)
Member: 2181415
Sonork: 100.1667029
Thanks Meter: 14
step_1
step_2
step_3
step_4
step_5
step_6
step_7
step_8
step_9
step_10
step_11
step_12
step_13
step_14
very good site tnk ...............
The Following 2 Users Say Thank You to alina919 For This Useful Post:
Page generated in 0.17171 seconds with 9 queries
