03-17-2017, 20:32 | #19 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Denmark
Member: 1839857 Status: Offline Thanks Meter: 46 | This is for sure nand problem, just fixed a 6+ with this problem by reballing the nand. I checked the nand in my programmer and everything was ok, so soldered it back in and phone was back alive. |
04-03-2017, 13:31 | #21 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2115441 Status: Offline Thanks Meter: 0 | Hi! Did anybody find the solution! I also have a very slight water damaged iPhone 6 (only top of the phone has small trace of water) I have cleaned and when i plug in to my laptop, iTunes detect him in DFU mode and when I try to restore - "software for this iphone is not currently available." Thank you! |
04-04-2017, 10:53 | #23 (permalink) |
No Life Poster Join Date: Sep 2005 Location: London, UK
Member: 178513 Status: Offline Thanks Meter: 109 | Did the iTune give any error number? did You try as well with 3U Tool? Give us more details. Pls for others to create their owen thread and not creating confusion... Thnx. |
04-18-2017, 05:28 | #29 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1225078 Status: Offline Thanks Meter: 10 | The iTunes is not recognizing the phone properly so it says that phone firmware is not available. It's very likely to be nand problem you need reball it. There is an import information of phone model that is recorded on nand ic. |
