06-11-2018, 12:22 | #1 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1889066 Status: Offline Thanks Meter: 1 | iphone 6 stuck on apple logo and not charging |
The Following User Says Thank You to Jasir777 For This Useful Post: |
06-12-2018, 08:40 | #2 (permalink) |
Freak Poster Join Date: May 2018
Member: 2833946 Status: Offline Thanks Meter: 108 | Charging fault analysis Plug dongle to computer, open PCB diagram software, iPhone 6 PCB diagram, Charing voltage input PP5V0_USB, battery voitage PP_BATT_VCC, Battery electric quantity dectection BATTERY_SWI_CONN, Connect U1401, Tigris charger, USB control IC, overvoltage protection signal, U1700 damage can result in not charging, reboot and connect computer failure ect. Charging fault detection Open iPhone 6 screen, take down the screen, pull up the battery connector from logic board. The coltage is about 2.0V after measurement through stitch battery is ok. Plug to charger, the voltage is 0.5V(normal 1.8V - 4.2V) after measurement through FPC connector, logic board can't charge Repair: Take out the logic board, fix the logic board with PCB holder. **** the shield cover with 320℃ air hot gun and take off it. After ****ing for 1 minute at 240℃, scrape off the black ashesive. **** the Bonding Pad for 1 minute at 300℃ until the tin melts, pry the chip with sculpture knife, apply some Paste Flux, remove the tin on bonding pad, apply some rosin on the Solder Wick and slick Bonding Pad, clearn the Bonding Pad with PCB Cleaner, align the new chip in right direction through stitch. **** the chip with hot gun for 1 minute at 280℃. Install the logic board after cool down Watch the video please go to here |
The Following 4 Users Say Thank You to AmieeWhite For This Useful Post: |
06-19-2018, 09:51 | #3 (permalink) | |
No Life Poster Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 494 | Thanks Brian for job Quote:
11-12-2018, 04:02 | #4 (permalink) | |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | Quote:
