07-20-2018, 08:16 | #1 (permalink) |
Freak Poster Join Date: May 2018
Member: 2833946 Status: Offline Thanks Meter: 108 | iTunes Error Codes of iPhone 6 Error Code 1 Baseband CPU, Baseband PMU, 19.2MHz Clock signal. Check if condition of voltage outputted from Baseband PMU, if there is no voltage outputted, please check if the Baseband PMU or Baseband CPU is pseudo soldered or damaged. Error Code -1 EPROM Check if the EPROM is pseudo soldered or damaged. Error Code 56 NFC circuit, the Rear camera circuit Check the condition of rear camera, the malfunction of rear camera and related circuit could cause error code 56. Check if the NFC IC is pseudo soldered or damaged. Error Code 4013, 4014 CPU Check the condition of CPU power supply or components on power supply rails. Check if the CPU is pseudo soldered or damaged. Tips for Troubleshooting All The iTunes Error Codes of iPhone 6/ 6 Plus Error Code 9, 14, 40, 2009, 4005 NAND flash 1. Check whether the NAND flash chip is pseudo soldered or damaged by measuring related resistance. 2. Replace the NAND flash chip. Error Code 2005 Battery, Voltage supply 1. Replace with anew battery to exclude the external malfunction factor. 2. Check the circuits related to battery connector. Error Code 3194 Network, USB cable, Charging port connector 1. Confirm whether your device is connected to internet. 2. Check the condition of USB cable. 3. Check if the charging port connector is pseudo soldered or damaged. Is the guide hard to understand? Also ready a video tutorial for you. https://blog.rewatechnology.com/tips...iphone6-6plus/ |
The Following User Says Thank You to AmieeWhite For This Useful Post: |
