10-03-2016, 13:44 | #1 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2592931 Status: Offline Thanks Meter: 1 | iPhone 6 no sound from earpieace after screen change this has happened to the last 2 iPhone 6 which needed a screen change. The phone works perfectly (everything) but after a few days there is no sound from earpiece. Everything else still works. NO water damage. I have changed the earpiece but still no sound. Can someone help please. |
10-03-2016, 14:55 | #3 (permalink) | |
Member: 2592931 Status: Offline Thanks Meter: 1 | Quote:
The caller can hear me so microphone works. All other sounds work (ringer etc) Could you explain what you mean by 'try no charging port'? Thank you | |
10-03-2016, 16:05 | #6 (permalink) |
Member: 2592931 Status: Offline Thanks Meter: 1 | [QUOTE=tarakhail;12077167]Or disconnect the old charging port and make call I disconnected the 'Lightning connector assembly cable' and I still get no sound from earpiece and no sound from external speaker (obviously) What can i try next? Getting panicky |
10-03-2016, 16:35 | #7 (permalink) | |
What can i try next? Getting panicky I have ordered a new charging assembly cable, it it worth changing the front camera, proximity sensor cable (although these all work as they should)? | |
