05-20-2015, 22:43 | #2 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2383261 Status: Offline Thanks Meter: 0 | Before You Start As always: Use the latest version of iTunes Make sure iPhone has enough space to bring in a new update. A gig or more is recommended. Also make sure the iPhone is not low on battery. The Real Problem Error 4014 (or 4013) is usually associated with a hardware problem – a faulty cable, a faulty port etc. On the surface, your iPhone connects to the computer, iTunes recognizes the device but somewhere down the line, iTunes thinks that the cable is not really that good. Or may be the port isn’t. The first thing you try should be change the USB port to which you connect the iPhone. Next up, change the cable that you use. Arguably, this has worked not for everyone but for a few people. As an extreme measure, you can also try updating from some other computer which has the latest iTunes installed. Backing Up and Going Into Recovery Mode If you are trying to update the firmware without doing a clean restore but running into this error (even after changing the cables), it’s time to cut the chase. This method is usually recommended as the last-thing-to-try but I think it’s easier to get this done with right away. Connect your iPhone to the computer. Fire up iTunes. Backup your iPhone. Now disconnect the iPhone, quit iTunes. Put the iPhone in recovery mode. The short version goes like this: press and hold power and home buttons till the screen goes blank. Open iTunes on PC. Connect the iPhone. iTunes should indicate (through a dialog box) that an iPhone is detected in recovery mode. Now go ahead and restore the device as new. This will erase everything but you will have the backup to restore from. Some Notes Occasionally, the error seems to vanish when people update to the last iOS 6.x version and then update to iOS 7. (This applies when you are on iOS 6.0, 6.1). Clear out apps and app memory to free up space on your iPhone. Although this sounds very unrelated to this error, it has helped. |
06-05-2015, 02:27 | #3 (permalink) |
No Life Poster Join Date: May 2015 Location: Los Angeles
Member: 2398349 Status: Offline Thanks Meter: 62 | sometimes it happens wen u use a after market part on the phone. open the phone and check what had been changed. change it back with the original part, u'll be just fine. the most common part for this error is the screen or sensor. so restore the phone without screen or sensor to see if its working or not and let me know!! |
10-08-2018, 10:12 | #4 (permalink) |
Junior Member Join Date: Aug 2018 Location: new york
Member: 2861348 Status: Offline Thanks Meter: 4 | follow the below methods to check and fix the iTunes error 4013 issue check the computer check the USB cable/port check the Wi-Fi hard reset your iPhone third party tool |
10-10-2018, 09:44 | #7 (permalink) |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | to save iphone 6 restore error 4013 and seeking for logic board solution, you can rule out some basic causes first as following: 1. Update iTunes to the latest version. 2. Update your computer to the latest OS. 3. Restart your computer and soft reset your iOS device. 4. Unplug and plug in your iOS device to try again. Error Code 4013, 4014 Check the condition of CPU power supply or components on power supply rails. Check if the CPU is pseudo soldered or damaged. |
The Following 4 Users Say Thank You to Amanda0820 For This Useful Post: |
11-13-2018, 08:20 | #9 (permalink) |
Freak Poster Join Date: Jul 2013 Location: karimnagar
Member: 1986680 Status: Offline Sonork: 7210 Thanks Meter: 21 | check capactiors and itz voltage beside nand...and remove shorted capatiors..hope this might help you |
The Following User Says Thank You to kunal124 For This Useful Post: |
