Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 07-15-2021, 15:29   #1 (permalink)
Member: 2642070
Thanks Meter: 15
apple watch s3/42mm FDR 0955AF78 error
[info] Using LOCAL IPSW F:\APPLE WATCH 7.5\MFC_Watch3,2_7.5_18T567_n111bAP_GPS_Cellular_R estore_42mm.ipsw
[info] using cached version data
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[info] Identified device as Apple Watch S3, n111bap, Watch3,2
[info] Extracting BuildManifest from ipsw
[data] Product Version: 7.5
[data] Product Build: 18T567 Major: 18
[info] device serial number is FH7VV10YJ6GM
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 00153446046840a6
[info] Getting ApNonce in recovery mode... [data] 3921A1876C81A531E64B432EF07549642F043DF87B4FCD5987 22ADC80744DC71
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 5C72B73B346F9D9B7FDE20FFF19D8C69180EE29B
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,2_7.5_18T567_n111bAP_GPS_Cellular_Resto re_42mm/018-19182-077.dmg'
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n111b.RELEASE.im4p...
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (773157 bytes)...
[info] Device ecid 00153446046840a6 disconnect detected!
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-6723.120.36
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting applelogo@132~watch.im4p...
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (9312 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Extracting 018-19204-077.dmg.trustcache...
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (15228 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 018-19204-077.dmg...
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (78786402 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n111bap.im4p...
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (33394 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Extracting sep-firmware.n111b.RELEASE.im4p...
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (2361886 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch3...
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (13381771 bytes)...
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device 3ca4b5893bed49a81b2ad05197dc85051fe9784f has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 30
[info] ChipID: 32772
[info] UniqueChipID: 5968449837220006
[info] ProductionMode: true
[sett] Previous restore exit status: 0x100
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49158)
[warn] Requesting NOT TO Update Baseband
[info] About to send RootTicket...
[info] Sending RootTicket now...
[info] Done sending RootTicket
[info] Waiting for NAND (28)
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[erro] zip_name_locate: Firmware/all_flash/manifest
[info] Getting firmware manifest from build identity
[info] Extracting LLB.n111b.RELEASE.im4p...
[info] Personalizing IMG4 component LLB...
[info] Extracting dali-ui.n111b.release.im4p...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Extracting recoverymode@132~watch.im4p...
[info] Personalizing IMG4 component RecoveryMode...
[info] Extracting iBoot.n111b.RELEASE.im4p...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[info] Done sending NORData
[info] Unmounting filesystems (29)
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checking for uncollected logs (44)
[info] Creating partition map (11)
[info] Creating filesystem (12)
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Checking filesystems (15)
[info] Mounting filesystems (16)
[info] Connecting to FDR client at port 49158
[info] FDR 0955C280 Proxy connect request to gg.apple.com:443
[info] FDR 0955C5B0 Proxy connect request to skl.apple.com:443
[info] FDR 0955AD08 Proxy connect request to skl.apple.com:443
[erro] FDR 0955C280 Unable to receive proxy payload (-3)
[info] FDR 0955C2B0 Proxy connect request to skl.apple.com:443
[info] FDR 0955AF78 Proxy connect request to skl.apple.com:443
[erro] FDR 0955C5B0 Unable to receive proxy payload (-3)
[erro] FDR 0955AD08 Unable to receive proxy payload (-3)
[info] Operation: Unknown operation (80)
[info] Sending IsiBootEANFirmware image list
[info] Sending IsiBootNonEssentialFirmware image list
[info] Flashing firmware (18)
[info] Sending IsEarlyAccessFirmware image list
[info] Operation: Requesting FUD data (36)
[info] Found IsFUDFirmware component ACIBT
[info] Found IsFUDFirmware component ACIWIFI
[info] Found IsFUDFirmware component AOP
[info] Found IsFUDFirmware component Multitouch
[info] Found IsFUDFirmware component RTP
[info] Found IsFUDFirmware component RestoreTrustCache
[info] Found IsFUDFirmware component StaticTrustCache
[info] Sending IsFUDFirmware image list
[info] Extracting BT_FW.im4p...
[info] Personalizing IMG4 component ACIBT...
[info] Sending IsFUDFirmware for ACIBT...
[info] Extracting wifi_armv7r_m8p_rtkit_image.im4p...
[info] Personalizing IMG4 component ACIWIFI...
[info] Sending IsFUDFirmware for ACIWIFI...
[info] Extracting aopfw-m8paop.im4p...
[info] Personalizing IMG4 component AOP...
[info] Sending IsFUDFirmware for AOP...
[info] Extracting N111b_Multitouch.im4p...
[info] Personalizing IMG4 component Multitouch...
[info] Sending IsFUDFirmware for Multitouch...
[info] Extracting rtpfw.im4p...
[info] Personalizing IMG4 component RTP...
[info] Sending IsFUDFirmware for RTP...
[info] Sending IsFUDFirmware for RestoreTrustCache...
[info] Extracting 018-19182-077.dmg.trustcache...
[info] Personalizing IMG4 component StaticTrustCache...
[info] Sending IsFUDFirmware for StaticTrustCache...
[info] Updating gas gauge software (47)
[info] Updating Stockholm (55)
[info] device disconnect...
[erro] FDR 0955AF78 Unable to receive proxy payload (-3)
[erro] Could not read data (-256). Aborting.
[erro] Unable to restore device
[done] Operation finished!
what this is problem after flasing MFC_TestFDR
Old 07-15-2021, 18:05   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
Check NFC or NFC Sensor if touch screen work good !
Page generated in 0.14175 seconds with 8 queries
