07-02-2021, 01:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Planet Earth
Member: 79937 Status: Offline Sonork: 100.84313 Thanks Meter: 4,715 | Apple Watch S4 44mm Flashing Success Here is the log: [warn] Operation aborted by user! [done] Operation finished! [info] Using LOCAL IPSW C:\Users\Rizwan\Downloads\MFC_Watch4,2_7.5_18T567_ n131bap_GPS_Restore_44mm.ipsw [info] Updated version data. [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131bap, Watch4,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.5 [data] Product Build: 18T567 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 00111d020a11002e [info] Getting ApNonce in dfu mode... [data] E3C9A82FA63BF366AE4A1A379FEB0F7C5A0407A4AC5EDD1453 264BA9573A244F [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] C818FF93695EF01F6A8A193989FA5C07B720C330 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch4,2_7.5_18T567_n131bap_GPS_Restore_44mm/018-19609-077.dmg [info] Extracting filesystem [info] Found ECID 00111d020a11002e [info] Getting ApNonce in dfu mode... [data] E3C9A82FA63BF366AE4A1A379FEB0F7C5A0407A4AC5EDD1453 264BA9573A244F [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] C818FF93695EF01F6A8A193989FA5C07B720C330 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (1129125 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 00111d020a11002e disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: e3 c9 a8 2f a6 3b f3 66 ae 4a 1a 37 9f eb 0f 7c 5a 04 07 a4 ac 5e dd 14 53 26 4b a9 57 3a 24 4f [info] Extracting iBEC.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1129125 bytes)... [info] Device ecid 00111d020a11002e disconnect detected! [info] device serial number is G99Y83C8KDH0 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.120.36 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10948 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1786649 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1861453 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1730909 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (1735829 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (848101 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-19158-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16358 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20341 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160145 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31700 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-19158-077.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (82714264 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (39639 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (5283198 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11752306 bytes)... [info] Device ecid 00111d020a11002e disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-00111D020A11002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 10 [info] ChipID: 32774 [info] UniqueChipID: 4816969200107566 [info] ProductionMode: true [sett] Previous restore exit status: 256 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Updating NAND Firmware (58) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5E8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A600 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A600 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 13B5C138 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5E8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5E8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 13B62390 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 13B622A0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A5D0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A708 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DA5A720 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA0FE8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA11C8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA11E0 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA1180 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA12E8 Proxy connect request to xp.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DAA12E8 Proxy connect request to xp.apple.com:443 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N131B_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N131b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-19158-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 018-19609-077.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Extracting Stockholm5.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! |
The Following User Says Thank You to .::iRizwan::. For This Useful Post: |
