Apple Watch Series 3 restore error Hi please check i am getting error in restoring apple watch series 3 Welcome to our iMFC server ProductType:Apple Watch S3 Starting ... Operation aborted by user! Operation finished! Starting ... Using LOCAL IPSW C:\Users\SHOPPETITE\Downloads\MFC_Watch3,2_19U67_8 .7.1_n111bAP_GPS_Cellular_Restore_42mm-001.ipsw Loading version data from Apple Server Updated version data. Found device in DFU mode Gettting dfu mode device ... Identified device as Apple Watch S3, n111bap, Watch3,2 Extracting BuildManifest from ipsw Product Version: 8.7.1 Product Build: 19U67 Major: 19 Device supports Image4: true Variant: Customer Erase Install (IPSW) This restore will erase your device data. Checking IPSW for required components... All required components found in IPSW Found ECID 0001551a180940a6 Getting ApNonce in dfu mode... 9A8D417539F97BDA39C24E677AAB0648B20EEE2F1FD73153ED EC099E3D7B1B06 tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... B361E86EFC69535AC8AB50EC485DBC0C849270D7 Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Using cached filesystem from 'iDeviceTools/MFC_Watch3,2_19U67_8.7.1_n111bAP_GPS_Cellular_Rest ore_42mm-001/078-33076-074.dmg' Found ECID 0001551a180940a6 Getting ApNonce in dfu mode... 9A8D417539F97BDA39C24E677AAB0648B20EEE2F1FD73153ED EC099E3D7B1B06 tts>Trying to fetch new SHSH blob Getting SepNonce in dfu mode... B361E86EFC69535AC8AB50EC485DBC0C849270D7 Unable to find BbCalibrationManifestKeyHash node Unable to find BbFactoryActivationManifestKeyHash node Unable to find BbSkeyId node Sending TSS request... Request URL set to https://gs.apple.com/TSS/controller?action=2 Sending TSS request attempt 1... response successfully received tts>Received SHSH blobs Extracting iBSS.n111b.RELEASE.im4p... Personalizing IMG4 component iBSS... Sending iBSS (773157 bytes)... If device does not disconnect automatically you can try to disconnect and reconnect the cable! Device ecid 0001551a180940a6 disconnect detected! Waiting for device arrival (timeout 20.000000 seconds) Found device in Recovery mode Noce: 9a 8d 41 75 39 f9 7b da 39 c2 4e 67 7a ab 06 48 b2 0e ee 2f 1f d7 31 53 ed ec 09 9e 3d 7b 1b 06 Extracting iBEC.n111b.RELEASE.im4p... Personalizing IMG4 component iBEC... Sending iBEC (773157 bytes)... Device ecid 0001551a180940a6 disconnect detected! device serial number is FHLVQQ96J6GF Recovery Mode Environment: iBoot build-version=iBoot-7459.140.15 iBoot build-style=RELEASE Sending AppleLogo... No path for component AppleLogo in TSS, will fetch from build_identity Extracting applelogo@132~watch.im4p... Personalizing IMG4 component AppleLogo... Sending AppleLogo (9313 bytes)... No path for component RestoreTrustCache in TSS, will fetch from build_identity Extracting 078-33379-076.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending RestoreTrustCache (15624 bytes)... No path for component RestoreRamDisk in TSS, will fetch from build_identity Extracting 078-33379-076.dmg... Personalizing IMG4 component RestoreRamDisk... Sending RestoreRamDisk (84828514 bytes)... No path for component RestoreDeviceTree in TSS, will fetch from build_identity Extracting DeviceTree.n111bap.im4p... Personalizing IMG4 component RestoreDeviceTree... Sending RestoreDeviceTree (33561 bytes)... No path for component RestoreSEP in TSS, will fetch from build_identity Extracting sep-firmware.n111b.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Sending RestoreSEP (2337346 bytes)... No path for component RestoreKernelCache in TSS, will fetch from build_identity Extracting kernelcache.release.watch3... Personalizing IMG4 component RestoreKernelCache... Sending RestoreKernelCache (14632856 bytes)... Device ecid 0001551a180940a6 disconnect detected! About to restore device... Waiting for device... Device is now connected in restore mode... Connecting now... Connected to com.apple.mobile.restored, version 15 Device 980ff07b3a3f20e97b753b73f7e96dfda4459be1 has successfully entered restore mode Hardware Information: BoardID: 30 ChipID: 32772 UniqueChipID: 375045537480870 ProductionMode: true Starting FDR listener thread Connecting to FDR client at port 1082 About to do ctrl handshake Ctrl handshake done (ConnPort = 49158) Requesting NOT TO Update Baseband Checkpoint 1621 complete with code 0 Checkpoint 1540 complete with code 0 Checkpoint 1679 complete with code 0 About to send RootTicket... Sending RootTicket now... Done sending RootTicket Checkpoint 1547 complete with code 0 Waiting for NAND (28) Checkpoint 1549 complete with code 0 Checkpoint 1550 complete with code 0 Checkpoint 1551 complete with code 0 Checkpoint 1628 complete with code 0 Checkpoint 1552 complete with code 0 Checkpoint 1555 complete with code 0 Checkpoint 1662 complete with code 0 Sending NORData... Found firmware path Firmware/all_flash zip_name_locate: Firmware/all_flash/manifest Getting firmware manifest from build identity Extracting LLB.n111b.RELEASE.im4p... Personalizing IMG4 component LLB... Extracting applelogo@132~watch.im4p... Personalizing IMG4 component AppleLogo... Extracting dali-ui.n111b.release.im4p... Personalizing IMG4 component Dali... Extracting DeviceTree.n111bap.im4p... Personalizing IMG4 component DeviceTree... Extracting recoverymode@132~watch.im4p... Personalizing IMG4 component RecoveryMode... Extracting iBoot.n111b.RELEASE.im4p... Personalizing IMG4 component iBoot... Extracting sep-firmware.n111b.RELEASE.im4p... Personalizing IMG4 component RestoreSEP... Extracting sep-firmware.n111b.RELEASE.im4p... Personalizing IMG4 component SEP... Sending NORData now... Done sending NORData Checkpoint 1545 complete with code 0 Checkpoint 1683 complete with code 0 Unmounting filesystems (29) Checkpoint 1637 complete with code 0 Checkpoint 1556 complete with code 0 Checkpoint 1686 complete with code 0 Checkpoint 1699 complete with code 0 Checkpoint 1695 complete with code 0 Checkpoint 1620 complete with code 0 Checkpoint 1687 complete with code 0 Checkpoint 1557 complete with code 0 About to send FDR Trust data... Sending FDR Trust data now... sending FDR Trust Data Checkpoint 1558 complete with code 0 Checkpoint 1559 complete with code 0 Checkpoint 1560 complete with code 0 Checking for uncollected logs (44) Checkpoint 1561 complete with code 0 Checkpoint 1562 complete with code 0 Checkpoint 1563 complete with code 0 Checkpoint 1633 complete with code 0 Unmounting filesystems (29) Checkpoint 1565 complete with code 0 Checkpoint 1614 complete with code 0 Checkpoint 1567 complete with code 0 Checkpoint 1674 complete with code 0 Creating partition map (11) Checkpoint 1569 complete with code 0 Checkpoint 1632 complete with code 0 Checkpoint 1570 complete with code 0 Checkpoint 1629 complete with code 0 Checkpoint 5645 complete with code 0 Creating filesystem (12) Checkpoint 1624 complete with code 0 Checkpoint 1625 complete with code 0 Checkpoint 1626 complete with code 0 About to send filesystem... Connected to ASR Validating the filesystem Filesystem validated Sending filesystem now... sending filesystem Operation: Verifying restore (14) Checkpoint 1627 complete with code 0 Checkpoint 1664 complete with code 0 Checkpoint 1653 complete with code 0 Checkpoint 1676 complete with code 0 Unmounting filesystems (29) Checking filesystems (15) Mounting filesystems (16) Checkpoint 1574 complete with code 0 Checkpoint 1634 complete with code 0 Checkpoint 1655 complete with code 0 Checkpoint 1658 complete with code 0 Checkpoint 1575 complete with code 0 Checkpoint 1690 complete with code 0 Checkpoint 1691 complete with code 0 Checkpoint 1618 complete with code 0 Connecting to FDR client at port 49158 FDR 09D0CA38 Proxy connect request to gg.apple.com:443 Connecting to FDR client at port 49158 FDR 09D0D200 Proxy connect request to skl.apple.com:443 Connecting to FDR client at port 49158 FDR 12B4B8B8 Proxy connect request to skl.apple.com:443 Connecting to FDR client at port 49158 FDR 09D0D200 Proxy connect request to skl.apple.com:443 Connecting to FDR client at port 49158 FDR 09B79F80 Proxy connect request to skl.apple.com:443 Checkpoint 1588 complete with code 0 Checkpoint 1661 complete with code 0 Operation: Unknown operation (80) Sending IsiBootEANFirmware image list Sending IsiBootNonEssentialFirmware image list Flashing firmware (18) Checkpoint 4864 complete with code 0 Operation: Unknown operation (80) Sending IsEarlyAccessFirmware image list Sending IsiBootEANFirmware image list Sending IsiBootNonEssentialFirmware image list Checkpoint 4882 complete with code 0 Operation: Requesting FUD data (36) Found IsFUDFirmware component ACIBT Found IsFUDFirmware component ACIWIFI Found IsFUDFirmware component AOP Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata Found IsFUDFirmware component Multitouch Found IsFUDFirmware component RTP Found IsFUDFirmware component RestoreTrustCache Found IsFUDFirmware component StaticTrustCache Found IsFUDFirmware component SystemVolume Sending IsFUDFirmware image list Extracting BT_FW.im4p... Personalizing IMG4 component ACIBT... Sending IsFUDFirmware for ACIBT... Extracting wifi_armv7r_m8p_rtkit_image.im4p... Personalizing IMG4 component ACIWIFI... Sending IsFUDFirmware for ACIWIFI... Extracting aopfw-m8paop.im4p... Personalizing IMG4 component AOP... Sending IsFUDFirmware for AOP... Extracting 078-33076-074.dmg.mtree... Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... Extracting N111b_Multitouch.im4p... Personalizing IMG4 component Multitouch... Sending IsFUDFirmware for Multitouch... Extracting rtpfw.im4p... Personalizing IMG4 component RTP... Sending IsFUDFirmware for RTP... Extracting 078-33379-076.dmg.trustcache... Personalizing IMG4 component RestoreTrustCache... Sending IsFUDFirmware for RestoreTrustCache... Extracting 078-33076-074.dmg.trustcache... Personalizing IMG4 component StaticTrustCache... Sending IsFUDFirmware for StaticTrustCache... Extracting 078-33076-074.dmg.root_hash... Personalizing IMG4 component SystemVolume... Sending IsFUDFirmware for SystemVolume... Checkpoint 4874 complete with code 0 Updating gas gauge software (47) Checkpoint 4865 complete with code 0 Updating gas gauge software (47) Checkpoint 4866 complete with code 0 Updating Stockholm (55) device disconnect... FDR 09B79F80 Unable to receive proxy payload (-3) Could not read data (-256). Aborting. Unable to restore device Failed Operation finished! Waiting for program to exit ... |
Check your hardware , this cased by touch screen and NFC related |
