Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 11-22-2022, 07:50   #1 (permalink)
Member: 605628
Apple Watch Series 3 restore error
Hi please check i am getting error in restoring apple watch series 3
Welcome to our iMFC server
ProductType:Apple Watch S3
Starting ...
Operation aborted by user!
Operation finished!
Starting ...
Using LOCAL IPSW C:\Users\SHOPPETITE\Downloads\MFC_Watch3,2_19U67_8 .7.1_n111bAP_GPS_Cellular_Restore_42mm-001.ipsw
Loading version data from Apple Server
Updated version data.
Found device in DFU mode
Gettting dfu mode device ...
Identified device as Apple Watch S3, n111bap, Watch3,2
Extracting BuildManifest from ipsw
Product Version: 8.7.1
Product Build: 19U67 Major: 19
Device supports Image4: true
Variant: Customer Erase Install (IPSW)
This restore will erase your device data.
Checking IPSW for required components...
All required components found in IPSW
Found ECID 0001551a180940a6
Getting ApNonce in dfu mode... 9A8D417539F97BDA39C24E677AAB0648B20EEE2F1FD73153ED EC099E3D7B1B06
tts>Trying to fetch new SHSH blob
Getting SepNonce in dfu mode... B361E86EFC69535AC8AB50EC485DBC0C849270D7
Unable to find BbCalibrationManifestKeyHash node
Unable to find BbFactoryActivationManifestKeyHash node
Unable to find BbSkeyId node
Sending TSS request...
Request URL set to https://gs.apple.com/TSS/controller?action=2
Sending TSS request attempt 1...
response successfully received
tts>Received SHSH blobs
Using cached filesystem from 'iDeviceTools/MFC_Watch3,2_19U67_8.7.1_n111bAP_GPS_Cellular_Rest ore_42mm-001/078-33076-074.dmg'
Extracting iBSS.n111b.RELEASE.im4p...
Personalizing IMG4 component iBSS...
Sending iBSS (773157 bytes)...
If device does not disconnect automatically you can try to disconnect and reconnect the cable!
Device ecid 0001551a180940a6 disconnect detected!
Waiting for device arrival (timeout 20.000000 seconds)
Found device in Recovery mode
Noce: 9a 8d 41 75 39 f9 7b da 39 c2 4e 67 7a ab 06 48 b2 0e ee 2f 1f d7 31 53 ed ec 09 9e 3d 7b 1b 06
Extracting iBEC.n111b.RELEASE.im4p...
Personalizing IMG4 component iBEC...
Sending iBEC (773157 bytes)...
device serial number is FHLVQQ96J6GF
Recovery Mode Environment:
iBoot build-version=iBoot-7459.140.15
iBoot build-style=RELEASE
Sending AppleLogo...
No path for component AppleLogo in TSS, will fetch from build_identity
Extracting [email protected]~watch.im4p...
Personalizing IMG4 component AppleLogo...
Sending AppleLogo (9313 bytes)...
No path for component RestoreTrustCache in TSS, will fetch from build_identity
Extracting 078-33379-076.dmg.trustcache...
Personalizing IMG4 component RestoreTrustCache...
Sending RestoreTrustCache (15624 bytes)...
No path for component RestoreRamDisk in TSS, will fetch from build_identity
Extracting 078-33379-076.dmg...
Personalizing IMG4 component RestoreRamDisk...
Sending RestoreRamDisk (84828514 bytes)...
No path for component RestoreDeviceTree in TSS, will fetch from build_identity
Extracting DeviceTree.n111bap.im4p...
Personalizing IMG4 component RestoreDeviceTree...
Sending RestoreDeviceTree (33561 bytes)...
No path for component RestoreSEP in TSS, will fetch from build_identity
Extracting sep-firmware.n111b.RELEASE.im4p...
Personalizing IMG4 component RestoreSEP...
Sending RestoreSEP (2337346 bytes)...
No path for component RestoreKernelCache in TSS, will fetch from build_identity
Extracting kernelcache.release.watch3...
Personalizing IMG4 component RestoreKernelCache...
Sending RestoreKernelCache (14632856 bytes)...
About to restore device...
Waiting for device...
Device is now connected in restore mode...
Connecting now...
Connected to com.apple.mobile.restored, version 15
Device 980ff07b3a3f20e97b753b73f7e96dfda4459be1 has successfully entered restore mode
Hardware Information:
BoardID: 30
ChipID: 32772
UniqueChipID: 375045537480870
ProductionMode: true
Starting FDR listener thread
Connecting to FDR client at port 1082
About to do ctrl handshake
Ctrl handshake done (ConnPort = 49158)
Requesting NOT TO Update Baseband
Checkpoint 1621 complete with code 0
Checkpoint 1540 complete with code 0
Checkpoint 1679 complete with code 0
About to send RootTicket...
Sending RootTicket now...
Done sending RootTicket
Checkpoint 1547 complete with code 0
Waiting for NAND (28)
Checkpoint 1549 complete with code 0
Checkpoint 1550 complete with code 0
Checkpoint 1551 complete with code 0
Checkpoint 1628 complete with code 0
Checkpoint 1552 complete with code 0
Checkpoint 1555 complete with code 0
Checkpoint 1662 complete with code 0
Sending NORData...
Found firmware path Firmware/all_flash
zip_name_locate: Firmware/all_flash/manifest
Getting firmware manifest from build identity
Extracting LLB.n111b.RELEASE.im4p...
Personalizing IMG4 component LLB...
Extracting dali-ui.n111b.release.im4p...
Personalizing IMG4 component Dali...
Personalizing IMG4 component DeviceTree...
Personalizing IMG4 component RecoveryMode...
Extracting iBoot.n111b.RELEASE.im4p...
Personalizing IMG4 component iBoot...
Personalizing IMG4 component SEP...
Sending NORData now...
Done sending NORData
Checkpoint 1545 complete with code 0
Checkpoint 1683 complete with code 0
Unmounting filesystems (29)
Checkpoint 1637 complete with code 0
Checkpoint 1556 complete with code 0
Checkpoint 1686 complete with code 0
Checkpoint 1699 complete with code 0
Checkpoint 1695 complete with code 0
Checkpoint 1620 complete with code 0
Checkpoint 1687 complete with code 0
Checkpoint 1557 complete with code 0
About to send FDR Trust data...
Sending FDR Trust data now...
sending FDR Trust Data
Checkpoint 1558 complete with code 0
Checkpoint 1559 complete with code 0
Checkpoint 1560 complete with code 0
Checking for uncollected logs (44)
Checkpoint 1561 complete with code 0
Checkpoint 1562 complete with code 0
Checkpoint 1563 complete with code 0
Checkpoint 1633 complete with code 0
Checkpoint 1565 complete with code 0
Checkpoint 1614 complete with code 0
Checkpoint 1567 complete with code 0
Checkpoint 1674 complete with code 0
Creating partition map (11)
Checkpoint 1569 complete with code 0
Checkpoint 1632 complete with code 0
Checkpoint 1570 complete with code 0
Checkpoint 1629 complete with code 0
Checkpoint 5645 complete with code 0
Creating filesystem (12)
Checkpoint 1624 complete with code 0
Checkpoint 1625 complete with code 0
Checkpoint 1626 complete with code 0
About to send filesystem...
Connected to ASR
Validating the filesystem
Filesystem validated
Sending filesystem now...
sending filesystem
Operation: Verifying restore (14)
Checkpoint 1627 complete with code 0
Checkpoint 1664 complete with code 0
Checkpoint 1653 complete with code 0
Checkpoint 1676 complete with code 0
Checking filesystems (15)
Mounting filesystems (16)
Checkpoint 1574 complete with code 0
Checkpoint 1634 complete with code 0
Checkpoint 1655 complete with code 0
Checkpoint 1658 complete with code 0
Checkpoint 1575 complete with code 0
Checkpoint 1690 complete with code 0
Checkpoint 1691 complete with code 0
Checkpoint 1618 complete with code 0
Connecting to FDR client at port 49158
FDR 09D0CA38 Proxy connect request to gg.apple.com:443
FDR 09D0D200 Proxy connect request to skl.apple.com:443
FDR 12B4B8B8 Proxy connect request to skl.apple.com:443
FDR 09B79F80 Proxy connect request to skl.apple.com:443
Checkpoint 1588 complete with code 0
Checkpoint 1661 complete with code 0
Operation: Unknown operation (80)
Sending IsiBootEANFirmware image list
Sending IsiBootNonEssentialFirmware image list
Flashing firmware (18)
Checkpoint 4864 complete with code 0
Sending IsEarlyAccessFirmware image list
Checkpoint 4882 complete with code 0
Operation: Requesting FUD data (36)
Found IsFUDFirmware component ACIBT
Found IsFUDFirmware component ACIWIFI
Found IsFUDFirmware component AOP
Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata
Found IsFUDFirmware component Multitouch
Found IsFUDFirmware component RTP
Found IsFUDFirmware component RestoreTrustCache
Found IsFUDFirmware component StaticTrustCache
Found IsFUDFirmware component SystemVolume
Sending IsFUDFirmware image list
Extracting BT_FW.im4p...
Personalizing IMG4 component ACIBT...
Sending IsFUDFirmware for ACIBT...
Extracting wifi_armv7r_m8p_rtkit_image.im4p...
Personalizing IMG4 component ACIWIFI...
Sending IsFUDFirmware for ACIWIFI...
Extracting aopfw-m8paop.im4p...
Personalizing IMG4 component AOP...
Sending IsFUDFirmware for AOP...
Extracting 078-33076-074.dmg.mtree...
Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata...
Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata...
Extracting N111b_Multitouch.im4p...
Personalizing IMG4 component Multitouch...
Sending IsFUDFirmware for Multitouch...
Extracting rtpfw.im4p...
Personalizing IMG4 component RTP...
Sending IsFUDFirmware for RTP...
Sending IsFUDFirmware for RestoreTrustCache...
Extracting 078-33076-074.dmg.trustcache...
Personalizing IMG4 component StaticTrustCache...
Sending IsFUDFirmware for StaticTrustCache...
Extracting 078-33076-074.dmg.root_hash...
Personalizing IMG4 component SystemVolume...
Sending IsFUDFirmware for SystemVolume...
Checkpoint 4874 complete with code 0
Updating gas gauge software (47)
Checkpoint 4865 complete with code 0
Checkpoint 4866 complete with code 0
Updating Stockholm (55)
device disconnect...
FDR 09B79F80 Unable to receive proxy payload (-3)
Could not read data (-256). Aborting.
Unable to restore device
Failed
Operation finished!
Waiting for program to exit ...
Old 11-22-2022, 09:32   #2 (permalink)
Member: 2277861
Thanks Meter: 144
Check your hardware , this cased by touch screen and NFC related
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.14719 seconds with 7 queries
