08-28-2020, 05:23 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Apple Watch S5, n144sap, Watch5,1 Done by iBUS S4/5 [info] using cached version data [info] Found device in Normal mode [info] Gettting normal mode device ... [info] Identified device as Apple Watch S5, n144sap, Watch5,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 25542390916xxxxx [info] Getting ApNonce in normal mode... [data] B8E8376D2EEE945C7A753F547721F8464069880FD7A9FEFAA6 BA4C299F8DD4DD [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in normal mode... [data] 7A765CD0C1D8EB67A0BFCAE742F23335793D825D [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [erro] Unable to get FirmwarePreflightInfo [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/Watch5,1_6.2.1_17T530_Restore/048-63939-310.dmg' [info] Found ECID 25542390916xxxxx [info] Checking if device requires stashbag... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [warn] Unable to find required ApECID in parameters, allowed to continue [warn] tss_request_add_ap_tags: Skipping 'SE,UpdatePayload' as it is neither firmware nor secondary firmware payload [info] Treating device as WatchOS [info] Device does not require stashbag. [info] Getting ApNonce in normal mode... [data] B8E8376D2EEE945C7A753F547721F8464069880FD7A9FEFAA6 BA4C299F8DD4DD [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in normal mode... [data] 9D65D5CE5221E2E117A0579D71D8207ACFD9B148 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [erro] Unable to get FirmwarePreflightInfo [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Entering recovery mode... [info] Removing USB\VID_05AC&PID_12AF\000080060009131121BB002E [info] device disconnect... [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:0009131121BB002E_IBFL:3 D_SRNM:[FHLZ4CY8MLTK] [info] device serial number is FHLZ4CY8MLTK [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n144s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1095083 bytes)... [info] Device ecid (565903406) added! [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:0009131121BB002E_IBFL:3 D_SRNM:[FHLZ4CY8MLTK] [info] Device ecid 25542390916xxxxx disconnect detected! [info] Device ecid (565903406) removed! [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:0009131121BB002E_IBFL:3 C_SRNM:[FHLZ4CY8MLTK] [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-5540.100.194 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@394~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9805 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1823338 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (2172010 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1674650 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch5aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (1395530 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (1654586 bytes)... [warn] No path for component RTP in TSS, will fetch from build_identity [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending RTP (3555297 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 048-63662-329.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15191 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (19126 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmwareT8006.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1159630 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (30281 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-63662-329.dmg... [info] Device ecid (565903406) added! [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (84756813 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n144sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (158687 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch5... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11253124 bytes)... [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:10_ECID:0009131121BB002E_IBFL:3 C_SRNM:[FHLZ4CY8MLTK] [info] Device ecid 2554239091671086 disconnect detected! [info] Device ecid (565903406) removed! [info] Adding USB\VID_05AC&PID_12AF\00008006-0009131121BB002E [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-0009131121BB002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 16 [info] ChipID: 32774 [info] UniqueChipID: 25542390916xxxxx [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Updating NAND Firmware (58) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n144s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@394~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n144s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n144sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@394~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n144s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n144s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n144s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checking filesystems (15) [info] Creating Protected Volume (67) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch5... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n144sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Flashing firmware (18) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-watch5aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N144S_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N144s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 048-63662-329.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmwareT8006.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 048-63939-310.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Extracting Stockholm5.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Fixing up /var (17) [info] Modifying persistent boot-args (25) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] Removing USB\VID_05AC&PID_12AF\00008006-0009131121BB002E [info] Adding USB\VID_05AC&PID_12AF\000080060009131121BB002E [info] device arrival... |
The Following 3 Users Say Thank You to .::Gsmdenis::. For This Useful Post: |
