10-18-2021, 00:32 | #18 (permalink) |
Insane Poster Join Date: Jan 2010 Location: Turkmenistan Ashgabat
Member: 1216178 Status: Offline Thanks Meter: 15 | I`ve tried on another computer and got this error: [erro] Unable to send data to ASR.Sent 0 of 20 bytes. [erro] Unable to send chunk checksum [erro] Unable to send payload to ASR [erro] Unable to send filesystem [erro] Unable to successfully restore device [info] Checkpoint 1627 complete with code 1100 [erro] Unable to restore device [done] Operation finished! |
10-18-2021, 00:35 | #19 (permalink) |
Member: 1216178 Status: Offline Thanks Meter: 15 | [info] Using LOCAL IPSW C:\Watch5,2_8.0_19R346_Restore.ipsw [info] Updated version data. [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S5, n144bap, Watch5,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 8.0 [data] Product Build: 19R346 Major: 19 [info] device serial number is G9CCW1R0MLTQ [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 00150b0e0a0b802e [info] Getting ApNonce in recovery mode... [data] 5EDF8D9F68824B138BD2AB4A3C697D209FD4B30B3F4255AC06 E884C6F9388713 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 49091D30A798754ED226261E16F9991216563105 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/Watch5,2_8.0_19R346_Restore/018-78404-002.dmg' [info] Found ECID 00150b0e0a0b802e [info] Getting ApNonce in recovery mode... [data] 5EDF8D9F68824B138BD2AB4A3C697D209FD4B30B3F4255AC06 E884C6F9388713 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 49091D30A798754ED226261E16F9991216563105 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n144b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1118744 bytes)... [info] Device ecid 00150b0e0a0b802e disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-7429.10.23.0.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10947 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1845625 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1905205 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1731589 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch5aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (2006165 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (881133 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-78678-002.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16710 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20345 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1176673 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31828 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-78678-002.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (87495832 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n144bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (42876 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n144b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (5463422 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch5... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13105161 bytes)... [info] Device ecid 00150b0e0a0b802e disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-00150B0E0A0B802E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 18 [info] ChipID: 32774 [info] UniqueChipID: 5923129436897326 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1679 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Updating NAND Firmware (58) [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checkpoint 1662 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n144b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n144b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n144bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n144b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n144b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n144b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 1545 complete with code 0 [info] Checkpoint 1683 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1637 complete with code 0 [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1686 complete with code 0 [info] Checkpoint 1697 complete with code 0 [info] Checkpoint 1695 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1687 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 1560 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1561 complete with code 0 [info] Checkpoint 1562 complete with code 0 [info] Checkpoint 1563 complete with code 0 [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1565 complete with code 0 [info] Checkpoint 1614 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1674 complete with code 0 [info] Creating partition map (11) [info] Checkpoint 1569 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Checkpoint 5645 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [erro] Unable to send data to ASR.Sent 0 of 20 bytes. [erro] Unable to send chunk checksum [erro] Unable to send payload to ASR [erro] Unable to send filesystem [erro] Unable to successfully restore device [info] Checkpoint 1627 complete with code 1100 [erro] Unable to restore device [done] Operation finished! [info] Removing USB\VID_05AC&PID_12AF |
10-18-2021, 02:42 | #21 (permalink) | |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 208 | Quote:
10-19-2021, 00:13 | #23 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | You can help-me with IPhone XR [data] ModelNumber:MRY42 [info] Use DCSD cable selected [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [erro] Current DFU device (ChipId: 0x8020 BoardId: 12) does not exist in our database or data is incomplete! [done] Operation finished! |
10-19-2021, 04:03 | #24 (permalink) | |
