Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 04-17-2024, 10:11   #1 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 108
Error restoring Watch 2 please help me I tried checking all the boxes beside the soft
[info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CPFM:03_SCEP:01_BDID:0C_ECID:0002122424BB4326_IBFL:3C_SRNM:[FH7TC9M0HJLL])
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-5540.144.2
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Personalizing IMG4 component AppleLogo...
[info] Sending AppleLogo (8178 bytes)...
[warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreTrustCache...
[info] Sending RestoreTrustCache (13919 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreRamDisk...
[info] Sending RestoreRamDisk (77415685 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreDeviceTree...
[info] Sending RestoreDeviceTree (110731 bytes)...
[warn] No path for component RestoreSEP in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreSEP...
[info] Sending RestoreSEP (2103233 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Personalizing IMG4 component RestoreKernelCache...
[info] Sending RestoreKernelCache (11149214 bytes)...
[info] Device ecid 0002122424bb4326 disconnect detected!
[info] About to restore device...
[info] Waiting for device...
[info] Device is now connected in restore mode...
[info] Connecting now...
[info] Connected to com.apple.mobile.restored, version 15
[info] Device d43549250a551814d38e4407d6d3f9a29346295b has successfully entered restore mode
[info] Hardware Information:
[info] BoardID: 12
[info] ChipID: 32770
[info] UniqueChipID: 582896397796134
[info] ProductionMode: true
[sett] Previous restore exit status: 0x100
[info] Starting FDR listener thread
[info] Connecting to FDR client at port 1082
[warn] About to do ctrl handshake
[done] Ctrl handshake done (ConnPort = 49158)
[warn] Requesting NOT TO Update Baseband
[erro] TZ0RequiredCapacity: 0x600000[info] Checkpoint 1621 complete with code 0
[info] Checkpoint 1540 complete with code 0
[info] About to send RootTicket...
[info] Sending RootTicket now...
[done] sending RootTicket
[info] Checkpoint 1547 complete with code 0
[info] Waiting for NAND (28)
[info] Checkpoint 1549 complete with code 0
[info] Checkpoint 1550 complete with code 0
[info] Checkpoint 1551 complete with code 0
[info] Checkpoint 1628 complete with code 0
[info] Checkpoint 1552 complete with code 0
[info] Checkpoint 1555 complete with code 0
[info] Checkpoint 1662 complete with code 75
[info] Checkpoint 1660 complete with code 0
[info] Checkpoint 5652 complete with code 0
[info] Checkpoint 1607 complete with code 0
[info] Status message: Missing data volume on APFS formatted device, erase required, please use RESTORE
[sett] Log is available in ErrorLog.plist
[erro]  Unable to successfully restore device
[info] Checkpoint 1608 complete with code 0
[erro] Unable to restore device
[done] Operation finished!
[info] Removed (Apple, Inc.,USB\VID_05AC&PID_12AF\D43549250A551814D38E4407D6D3F9A29346295B)
[info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CPFM:03_SCEP:01_BDID:0C_ECID:0002122424BB4326_IBFL:3D_SRNM:[FH7TC9M0HJLL])
[info] Using local file D:\MFCBOX\iWatch Firmware\MFC_Watch2,6_n27dap_38mm_Watch2,3_n74ap_38mm_6.3_17U208_restore.ipsw
[erro] We don't know firmware locations for device OS type!
[info] Found device in Recovery mode
[info] Gettting dfu mode device ...
[warn] Phone model not found, please send email to [email protected], Thank you!
[info] Extracting BuildManifest from ipsw
[data] Product Version: 6.3
[data] Product Build: 17U208 Major: 17
[info] device serial number is FH7TC9M0HJLL
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] Checking for required components...
[info] Using ECID 0002122424bb4326
[info] Getting ApNonce in recovery mode... [data] B36B7E95FFDF1A8C8E40E748F2E69CE2E47140ED5053B1C9D55102D1014DBDA1
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] 35155C5A26B42F726EBE198F61365A460763773B
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[warn] Unable to find component node for Cryptex1,SystemOS
[info] Using cached file 'iDeviceTools\MFC_Watch2,6_n27dap_38mm_Watch2,3_n74ap_38mm_6.3_17U208_restore\038-87605-009.dmg'
[info] Found ECID 0002122424bb4326
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Personalizing IMG4 component iBEC...
[info] Sending iBEC (747975 bytes)...
[info] Removed (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CPFM:03_SCEP:01_BDID:0C_ECID:0002122424BB4326_IBFL:3D_SRNM:[FH7TC9M0HJLL])
[info] Sending RestoreTrustCache (13743 bytes)...
[info] Sending RestoreRamDisk (67956485 bytes)...
[info] BoardID: 12
[info] Checkpoint 1662 complete with code 0
[info] Sending NORData...
[info] Found firmware path Firmware/all_flash
[info] Getting firmware manifest from build identity
[info] Personalizing IMG4 component LLB...
[info] Personalizing IMG4 component Dali...
[info] Personalizing IMG4 component DeviceTree...
[info] Personalizing IMG4 component RecoveryMode...
[info] Personalizing IMG4 component iBoot...
[info] Personalizing IMG4 component SEP...
[info] Sending NORData now...
[done] Done sending NORData
[info] Checkpoint 1545 complete with code 0
[info] Unmounting filesystems (29)
[info] Checkpoint 1637 complete with code 0
[info] Checking filesystems (15)
[info] Checkpoint 1556 complete with code 0
[info] Checkpoint 1620 complete with code 0
[info] Checkpoint 1557 complete with code 0
[info] About to send FDR Trust data...
[info] Sending FDR Trust data now...
[done] sending FDR Trust Data
[info] Checkpoint 1558 complete with code 0
[info] Checkpoint 1559 complete with code 0
[info] Checkpoint 1560 complete with code 0
[info] Checkpoint 1561 complete with code 0
[info] Checkpoint 1562 complete with code 0
[info] Checkpoint 1563 complete with code 0
[info] Checkpoint 1633 complete with code 0
[info] Checkpoint 1565 complete with code 0
[info] Checkpoint 1614 complete with code 0
[info] Checkpoint 1619 complete with code 0
[info] Checkpoint 1567 complete with code 0
[info] Creating partition map (11)
[info] Checkpoint 1569 complete with code 0
[info] Checkpoint 1632 complete with code 0
[info] Checkpoint 1570 complete with code 0
[info] Checkpoint 1629 complete with code 0
[info] Checkpoint 5645 complete with code 0
[info] Creating filesystem (12)
[info] Checkpoint 1624 complete with code 0
[info] Checkpoint 1625 complete with code 0
[info] Checkpoint 1626 complete with code 0
[info] About to send filesystem...
[info] Connected to ASR
[info] Validating the filesystem
[info] Filesystem validated
[info] Sending filesystem now...
[erro] Unable to send data to ASR.Sent 0 of 20 bytes.
[erro] Unable to send chunk checksum
[erro] Unable to send payload to ASR
[erro] Unable to send filesystem
[erro] Could not read data (-256). Aborting.
Old 04-17-2024, 10:18   #2 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 108
This specific error:
Forum searching is disabled and searching on google with forum.gsmhosting.com like I search normally yields no results, so seems this error has not happened to anyone before
Old 04-17-2024, 14:11   #3 (permalink)
Member: 2277861
Thanks Meter: 208
try mac software if can get different result , thanks
Old 04-17-2024, 20:37   #4 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 108
Ok
Now when I tried again it went until the end almost but the watch gear stayed long time then at the end it just goes to recovery and this error message as in the end of the log:
[info] Getting ApNonce in recovery mode... [data] 78FCE9CF6130236E112F0583227AC0ADC645CE1C6EEED02CB9AB439CA9E6D32F
[info] Getting SepNonce in recovery mode... [data] BCCB8E607AD69FB8ED92E9CF68B155B6CB22BBEE
[info] BoardID: 12
[warn] Requesting Update Baseband
[done] sending filesystem
[info] Operation: Verifying restore (14)
[info] Checkpoint 1627 complete with code 0
[info] Checkpoint 1664 complete with code 0
[info] Checkpoint 1653 complete with code 0
[info] Creating Protected Volume (67)
[info] Checkpoint 1652 complete with code 0
[info] Checkpoint 3846 complete with code 0
[info] Mounting filesystems (16)
[info] Checkpoint 1574 complete with code 0
[info] Checkpoint 1631 complete with code 0
[info] Checkpoint 1634 complete with code 0
[info] Checkpoint 1655 complete with code 0
[info] Checkpoint 1658 complete with code 0
[info] Checkpoint 1575 complete with code 0
[info] About to send KernelCache...
[warn] No path for component KernelCache in TSS, will fetch from build identity
[info] Personalizing IMG4 component KernelCache...
[info] Sending KernelCache ...
[done] Done sending KernelCache
[info] Installing kernelcache (27)
[info] Checkpoint 3584 complete with code 0
[info] About to send DeviceTree...
[warn] No path for component DeviceTree in TSS, will fetch from build identity
[info] Sending DeviceTree ...
[done] Done sending DeviceTree
Old 04-18-2024, 00:44   #5 (permalink)
Member: 2277861
Thanks Meter: 208
means flex or Touch / NFC have problem , you need check hardware
Page generated in 0.25396 seconds with 8 queries
