FLASH S3gps error ? [fixed] flash s3 gps error ? help me [erro] Could not read data (-170158304). Aborting. [erro] Unable to receive message from FDR 10838958 (-3). 0/2 bytes [erro] FDR 08894280 Unable to receive proxy payload (-3) [erro] Unable to restore device [erro] FDR 088941D8 Unable to receive proxy payload (-3) [erro] FDR 08893F08 Unable to receive proxy payload (-3) [erro] FDR 088941C0 Unable to receive proxy payload (-3) [erro] FDR 08893FB0 Unable to receive proxy payload (-3) [info] Removing USB\VID_05AC&PID_12AF\312470A25687CF0DB84DE8A51EB2 213C262FC963 [info] Apple device disconnected! [done] Operation finished! |
What's the itunes version you are using now ? and are you sure you are using this mfc version ? https://www.mfcbox.com/downloads/mfc...ller-download/ |
I am using the latest itune 12.10.8 and MF final 3.3 |
Have the same issues with 3 watches S2 and S3. But with the same config I'm able to flash others normally. The same soft (itunes and mfc) and I'm sure that hardware is ok |
any news? I have same problem on S3 38mm GPS MFC_Watch3,3_17T530_6.2.1_n121sAP_GPS_Restore_38mm return in red sign mode |
I replace display on a s3 38 gps, I tried to see if the display it’s the problem but found that was the part from right connector... seems to be broken... Replace it and successfully restored |
Good job !!!! thanks for share |
server on from yesterday afternoon |
