Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle
Old 08-19-2020, 11:38   #1 (permalink)
Member: 2963850
FLASH S3gps error ?
flash s3 gps error ? help me
[erro] Could not read data (-170158304). Aborting.
[erro] Unable to receive message from FDR 10838958 (-3). 0/2 bytes
[erro] FDR 08894280 Unable to receive proxy payload (-3)
[erro] Unable to restore device
[erro] FDR 088941D8 Unable to receive proxy payload (-3)
[erro] FDR 08893F08 Unable to receive proxy payload (-3)
[erro] FDR 088941C0 Unable to receive proxy payload (-3)
[erro] FDR 08893FB0 Unable to receive proxy payload (-3)
[info] Removing USB\VID_05AC&PID_12AF\312470A25687CF0DB84DE8A51EB2 213C262FC963
[info] Apple device disconnected!
[done] Operation finished!
Old 08-19-2020, 19:11   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 5,372
What's the itunes version you are using now ?
and are you sure you are using this mfc version ?
https://www.mfcbox.com/downloads/mfc...ller-download/
Old 08-20-2020, 06:40   #3 (permalink)
Member: 2963850
I am using the latest itune 12.10.8 and MF final 3.3
Old 08-20-2020, 06:49   #4 (permalink)
Member: 2962418
Thanks Meter: 3
Have the same issues with 3 watches S2 and S3. But with the same config I'm able to flash others normally. The same soft (itunes and mfc) and I'm sure that hardware is ok
The Following User Says Thank You to JackOS78 For This Useful Post:
Old 08-26-2020, 13:57   #5 (permalink)
Member: 2263638
Thanks Meter: 2
any news? I have same problem on S3 38mm GPS
MFC_Watch3,3_17T530_6.2.1_n121sAP_GPS_Restore_38mm
return in red sign mode
Old 09-15-2020, 20:39   #6 (permalink)
Member: 2263638
Thanks Meter: 2
Today I found a solution for this problem.
I replace display on a s3 38 gps, I tried to see if the display itís the problem but found that was the part from right connector... seems to be broken...
Replace it and successfully restored
The Following User Says Thank You to zmeutz For This Useful Post:
Old 09-16-2020, 01:58   #7 (permalink)
Member: 79315
Thanks Meter: 5,372
Good job !!!!
thanks for share
Page generated in 0.26933 seconds with 7 queries
