Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle
Old 06-29-2020, 12:28   #1 (permalink)
Member: 1964660
Thanks Meter: 43
Hardware or mfc problem?
[info]
[info] Starting ...
[info] Using LOCAL IPSW D:\Iphone\Iwatch\3\MFC_Watch3,4_17T530_6.2.1_n121b AP_GPS_Restore_42mm.ipsw
[info] using cached version data
[info] Found device in Recovery mode
[info] Identified device as Apple Watch S3, n121bap, Watch3,4
[info] Extracting BuildManifest from ipsw
[data] Product Version: 6.2.1
[data] Product Build: 17T530 Major: 17
[erro] Unable to connect to device in recovery mode
[data] Device supports Image4: false
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[erro] Unable to find device ECID
[info] Failed
[info]
[info] Starting ...
[info] Failed
[info] Starting ...
[warn] Another operation already in progress! Please wait...
[erro] Unable to discover device mode. Please make sure a device is attached.
[info] Failed
[info] Starting ...
[info] device serial number is FHLWH5WEJ5X4
[data] Device supports Image4: true
[info] Found ECID 1408002016284838
[info] Getting ApNonce in recovery mode... [data] 617BA3C4EEF78A2D33F890F90598F43C63DC0EA59F19EFA1C7 51B62D7D4BF5DD
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in recovery mode... [data] BA43212E5E6FFE465BA7483CBE2BC587F9159527
[warn] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[warn] Unable to find BbSkeyId node
[info] Sending TSS request...
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Extracting filesystem
[warn] No path for component iBEC in TSS, will fetch from build_identity
[info] Extracting iBEC.n121b.RELEASE.im4p...
[info] Sending iBEC (744155 bytes)...
[info] Recovery Mode Environment:
[info] iBoot build-version=iBoot-5540.100.194
[info] iBoot build-style=RELEASE
[info] Sending AppleLogo...
[warn] No path for component AppleLogo in TSS, will fetch from build_identity
[info] Extracting [email protected]~watch.im4p...
[info] Sending AppleLogo (8980 bytes)...
[warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity
[info] Extracting 048-63605-329.dmg...
[info] Sending RestoreRamDisk (68001303 bytes)...
[warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity
[info] Extracting DeviceTree.n121bap.im4p...
[info] Sending RestoreDeviceTree (114149 bytes)...
[warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity
[info] Extracting kernelcache.release.watch3...
[info] Sending RestoreKernelCache (12686537 bytes)...
[info] Restoring device...
[info] Waiting for device...
[erro] Unable to connect to device in restore mode
[erro] Unable to open device in restore mode
[erro] Unable to restore device
[info] Failed
[info] Starting ...
[info] Variant: Customer Upgrade Install (IPSW)
[info] This restore will update your device without losing data.
[info] Getting SepNonce in recovery mode... [data] 3CCF9A27496CECF7F55FAD51481B0C4E527FFED3
[info] Extracting 048-63982-330.dmg...
[info] Sending RestoreRamDisk (77460503 bytes)...
[info] Failed
Old 06-30-2020, 12:11   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 5,166
try to check restore and update 2 functions
Old 06-30-2020, 21:32   #3 (permalink)
Member: 1964660
Thanks Meter: 43
already try, same!!!
Old 06-30-2020, 21:51   #4 (permalink)
Member: 79315
Thanks Meter: 5,166
Focus on new update now , just need a little bit time
Page generated in 0.14033 seconds with 7 queries
