12-28-2017, 17:15 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2120342 Status: Offline Thanks Meter: 25 | IPhone 5C Flashing Problem [info] Starting ... [info] Using LOCAL IPSW D:\3uTools\Firmware\iPhone_4.0_32bit_10.3.3_14G60_ Restore.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as iPhone 5c Global, n49ap, iPhone5,4 [info] Extracting BuildManifest from IPSW [data] Product Version: 10.3.3 [data] Product Build: 14G60 Major: 14 [info] device serial number is FFMNC01AFFT5 [data] Device supports Image4: false [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Found ECID 2346160027082 [info] Getting ApNonce in recovery mode... [data] 5C618BB0C837140C7D2AE2C10397D2EBB2A98511 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/iPhone_4.0_32bit_10.3.3_14G60_Restore/058-74968-062.dmg' [info] Sending APTicket (2760 bytes) [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.iphone5b.RELEASE.dfu... [note] No SHSH blob found for component iBEC [info] Not personalizing component iBEC... [info] Sending iBEC (303308 bytes)... [info] Getting ApNonce in recovery mode... [data] 5C618BB0C837140C7D2AE2C10397D2EBB2A98511 [info] Sending APTicket (2760 bytes) [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-3406.60.10 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@2x~iphone.s5l8950x.img3... [note] No SHSH blob found for component AppleLogo [info] Not personalizing component AppleLogo... [info] Sending AppleLogo (6668 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-75393-062.dmg... [note] No SHSH blob found for component RestoreRamDisk [info] Not personalizing component RestoreRamDisk... [info] Sending RestoreRamDisk (25596044 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n49ap.img3... [note] No SHSH blob found for component RestoreDeviceTree [info] Not personalizing component RestoreDeviceTree... [info] Sending RestoreDeviceTree (89292 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.iphone5b... [note] No SHSH blob found for component RestoreKernelCache [info] Not personalizing component RestoreKernelCache... [info] Sending RestoreKernelCache (11695820 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 14 [info] Device a22854a092356417b9313b2bd4a6a3413ab6159b has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 35152 [info] UniqueChipID: 2346160027082 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] Retrying connection... [erro] Unable to connect to FDR client(-2) [erro] Failed to start FDR Ctrl channel [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] Unmounting filesystems (29) [info] Mounting filesystems (16) [info] Resizing system partition (52) [info] Unmounting filesystems (29) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.iphone5b... [note] No SHSH blob found for component KernelCache [info] Not personalizing component KernelCache... [done] sending KernelCache [info] Installing kernelcache (27) [info] Sending NORData... [note] Unable to find LLB path in TSS entry [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.iphone5b.RELEASE.img3... [info] Personalizing IMG3 component LLB... [info] reconstructed size: 158042 [info] Extracting applelogo@2x~iphone.s5l8950x.img3... [note] No SHSH blob found for component AppleLogo [info] Not personalizing component AppleLogo... [info] Extracting batterycharging0@2x~iphone.s5l8950x.img3... [note] No SHSH blob found for component BatteryCharging0 [info] Not personalizing component BatteryCharging0... [info] Extracting batterycharging1@2x~iphone.s5l8950x.img3... [note] No SHSH blob found for component BatteryCharging1 [info] Not personalizing component BatteryCharging1... [info] Extracting batteryfull@2x~iphone.s5l8950x.img3... [note] No SHSH blob found for component BatteryFull [info] Not personalizing component BatteryFull... [info] Extracting batterylow0@2x~iphone.s5l8950x.img3... [note] No SHSH blob found for component BatteryLow0 [info] Not personalizing component BatteryLow0... [info] Extracting batterylow1@2x~iphone.s5l8950x.img3... [note] No SHSH blob found for component BatteryLow1 [info] Not personalizing component BatteryLow1... [info] Extracting glyphplugin@1136~iphone-lightning.s5l8950x.img3... [note] No SHSH blob found for component BatteryPlugin [info] Not personalizing component BatteryPlugin... [info] Extracting DeviceTree.n49ap.img3... [note] No SHSH blob found for component DeviceTree [info] Not personalizing component DeviceTree... [info] Extracting recoverymode@1136~iphone-lightning.s5l8950x.img3... [note] No SHSH blob found for component RecoveryMode [info] Not personalizing component RecoveryMode... [info] Extracting iBoot.iphone5b.RELEASE.img3... [note] No SHSH blob found for component iBoot [info] Not personalizing component iBoot... [info] Sending NORData now... [info] Done sending NORData [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] About to send FUD data... [info] Sending FUD data now... [done] Done sending FUD data [info] Updating baseband (19) [erro] device didn't accept BasebandData [erro] Unable to successfully restore device [info] Verification Error [sett] Log is available in ErrorLog.plist [erro] Unable to restore device [info] Failed [info] Apple device disconnected! bb Problem plz help me |
