07-05-2022, 15:16 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Egypt Age: 30
Member: 1815000 Status: Offline Thanks Meter: 54 | iPhone 7 Ramdisk connect error [info] Connecting using DFU ... [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [info] Device is allready expoited! [info] Loading required files ... [info] Finished loading required files ... [erro] No matching config found for this image! [info] Patching failed! Maybe previously patched so trying to continue! [info] Shsh sent (file size:43462 bytes) [info] iBss sent (file size:522510 bytes) [info] iBec sent (file size:522510 bytes) [info] Devicetree sent (file size:36559 bytes) [info] Ramdisk sent (file size:120590224 bytes) [info] Kernel sent (file size:19818960 bytes) [info] Ramdisk ramdisk tool jun 29 2020 00:18:13 assigned to current device! [info] Connecting to ramdisk! [info] Connecting... [erro] ssh>connecting to 127.0.0.1: Socket error: Unknown error [erro] Error connecting to devices! [erro] ssh>connecting to 127.0.0.1: Socket error: Unknown error [warn] Failed to connect! [erro] Could not connect to Ramdisk [info] Please put the device in DFU mode and try again! |
07-05-2022, 15:19 | #2 (permalink) |
Member: 1815000 Status: Offline Thanks Meter: 54 | [info] Removing USB rules! [info] Connecting using DFU ... [info] Thread priority before boost is 0x2 [info] Current thread priority is 0xf [info] stage 1, heap grooming ... [info] Reset result: Success [info] stage 2, aquired [erro] Failed to send abort. [info] stage 3, exploit [info] Uploading payload and then phone start booting normally ... i must other ipwnder |
