08-30-2022, 07:07 | #1 (permalink) |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 206 | iPhone X (10,3) Diag aka purple mode successful logs [info] Connecting using DFU ... [info] Loading required files ... [info] Finished loading required files ... [info] Thread priority before boost is 0x2 [info] Current thread priority is 0xf [info] Payload size: 3072 overwrite offset: 0500 [info] stage 1, heap grooming ... [erro] Heap grooming failed! Aborting... [warn] Retrying heap grooming ... [info] Reset result: Success [info] stage 1, heap grooming ... [erro] Heap grooming failed! Aborting... [warn] Retrying heap grooming ... [info] Reset result: Success [info] stage 1, heap grooming ... [info] Reset result: Success [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [info] Reset result: Success [done] Device is now in pwned DFU Mode! [warn] Patching signatures using default method, press 1,2,3 to select [warn] Using V3 method! [info] Reset result: Success [info] Device is now ready to accept unsigned images [info] Sending FirstStage [info] FirstStage sent (file size:1468667 bytes) [warn] if device not reconnect automatically press and hold power button for 1~2 seconds and release [info] Sending commands ... [info] Sending DiagsStage [info] Selected port: COM14 [info] If the serial device is Diags CDC Serial the reccomended speed selection is 9600bps [info] Device is allready in Diag Mode on COM14 [done] Operation finished! [info] Opening \\.\COM14 with baudrate 115200 [info] Opening successfull! Tips: The following grooming errors may sometimes appear, you can press the "Load Diag" button to try again, but if it always fails, you will need to put the iPhone back into the DFU and repeat the step Code: [info] stage 1, heap grooming ... [erro] Heap grooming failed! Aborting... |
The Following User Says Thank You to mfcsupport For This Useful Post: |
