08-30-2022, 07:40 | #1 (permalink) |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 206 | iPhone X (10,3) Ramdisk successful logs [info] Connecting using DFU ... [info] Loading required files ... [info] Finished loading required files ... [info] Thread priority before boost is 0x2 [info] Current thread priority is 0xf [info] Payload size: 3072 Overwrite offset: 0500 [info] stage 1, heap grooming ... [info] Reset result: Success [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [info] Reset result: Success [done] Device is now in pwned DFU Mode! [warn] Patching signatures using default method, press 1,2,3 to select [warn] Using V1 method! [info] Reset result: Success [info] Device is now ready to accept unsigned images [info] Sending Shsh [info] Shsh sent (file size:63144 bytes) [info] Sending iBss [info] iBss sent (file size:1471378 bytes) [warn] if device not reconnect automatically press and hold power button for 1~2 seconds and release [info] Sending iBec [info] iBec sent (file size:1471378 bytes) [info] Sending Devicetree [info] Devicetree sent (file size:40461 bytes) [info] Sending Ramdisk [info] Ramdisk sent (file size:120590612 bytes) [info] Sending Adc [info] Adc sent (file size:13269959 bytes) [info] Sending Rdtrust [info] Rdtrust sent (file size:12226 bytes) [info] Sending Kernel [info] Kernel sent (file size:18721200 bytes) [info] Sleeping few seconds before connecting to ramdisk... [info] Ramdisk ramdisk tool jun 29 2020 00:18:13 assigned to current device! [info] Connecting... [erro] ssh>connecting to 127.0.0.1: Socket error: disconnected [info] Loading /mnt2 [info] Starting sesison! [info] Disconnecting ... [info] Connecting ... [info] ssh_userauth_password [info] Ramdisk SCPConnection session init required ... [info] Sending SSH command... [info] Sending SSH command successfull! [info] Ramdisk SCPConnection session init completed! [info] Listing path /mnt2 [info] Disconnecting SSHSession [info] FDH - Finished listing 0 files in 0 dirs [info] New root loaded: /mnt2 [done] Current root dir: /mnt2 |
