04-28-2015, 17:48 | #1 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2368730 Status: Offline Thanks Meter: 0 | Locked screen using MFC Dongle |
04-28-2015, 23:34 | #2 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | What is the iOS version of the phone? As long as you had the option to enter the code, MFC will not permanently disable you phone. |
04-30-2015, 01:25 | #5 (permalink) |
Freak Poster Join Date: Feb 2015
Member: 2352803 Status: Offline Thanks Meter: 6 | I'm trying the xxxx BOX right now. But same result. It's and IOS 7.xxx device. It got it once it should again. Sent from my iPhone using Tapatalk Last edited by .::Gsmdenis::.; 04-30-2015 at 06:45. Reason: edit other xxxx box |
04-30-2015, 08:10 | #6 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2287538 Status: Offline Thanks Meter: 3 | If you're unlocking IOS 7 devices then it is a part of the process that it will become permanently disabled, but it will continue attempting codes. It's normal for IOS 7. |
The Following User Says Thank You to andrenimri For This Useful Post: |
