Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 11-19-2021, 17:56   #1 (permalink)
Member: 985126
Sonork: 100.1626690
Thanks Meter: 199
I can't put it in diag mode
[info] Device present connection uses normal backend
[info] Connecting...
[info] Device present in DFU mode using normal backend
[info] Current thread priority is 0x0
[info] stage 1, heap grooming ...
[info] stage 2, aquired
[info] stage 3, exploit
[info] Uploading payload
[erro] Exploit failed!
Old 11-20-2021, 02:36   #2 (permalink)
Member: 985126
Sonork: 100.1626690
Thanks Meter: 199
[data] ProductType:Watch3,4
[info] Found device in DFU mode
[info] Identified device as Apple Watch S3, n121bap, Watch3,4
[done] Operation finished!
[info] Activate or deactivate a device.
[info] Using LOCAL IPSW C:\Users\DR PHONE RECEPCION\Downloads\MFC\SERIE 3 42MM GPS\MFC_Watch3,4_8.1_19R570_n121bAP_GPS_Restore_42 mm.ipsw
[info] using cached version data
[info] Gettting dfu mode device ...
[info] Extracting BuildManifest from ipsw
[data] Product Version: 8.1
[data] Product Build: 19R570 Major: 19
[data] Device supports Image4: true
[info] Variant: Customer Erase Install (IPSW)
[info] This restore will erase your device data.
[info] Checking IPSW for required components...
[info] All required components found in IPSW
[info] Found ECID 000611410e288026
[info] Getting ApNonce in dfu mode... [data] 39B7E37F7DFDCE37520AE7B79B54D64C05A157B1983EB542C1 FEFA8C640D3AD4
[info] tts>Trying to fetch new SHSH blob
[info] Getting SepNonce in dfu mode... [data] 2EC1054276BD5DCD45A149DA2B1E02219DF6D037
[note] Unable to find BbChipID node
[note] Unable to find BbProvisioningManifestKeyHash node
[note] Unable to find BbActivationManifestKeyHash node
[note] Unable to find BbCalibrationManifestKeyHash node
[note] Unable to find BbFactoryActivationManifestKeyHash node
[note] Unable to find BbFDRSecurityKeyHash node
[note] Unable to find BbSkeyId node
[info] Request URL set to https://gs.apple.com/TSS/controller?action=2
[info] Sending TSS request attempt 1...
[info] response successfully received
[info] tts>Received SHSH blobs
[info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_8.1_19R570_n121bAP_GPS_Restore_42mm/018-59188-082.dmg'
[info] Extracting iBSS.n121b.RELEASE.im4p...
[info] Personalizing IMG4 component iBSS...
[info] Sending iBSS (769060 bytes)...
[warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable!
[info] Device ecid 000611410e288026 disconnect detected!
[info] Waiting for device arrival (timeout 20.000000 seconds)
[info] Found device in Recovery mode
[info] Noce:
[info] Getting SepNonce in recovery mode... [info] device serial number is GJ9ZT9BLJ5X6
[erro] Unable to find required ApSepNonce in parameters
[erro] tts>Unable to add img4 tags to TSS request
[erro] Unable to get SHSH blobs for this device
[erro] Unable to place device into recovery mode from Recovery mode
Old 11-20-2021, 02:37   #3 (permalink)
Member: 985126
Sonork: 100.1626690
Thanks Meter: 199
Old 11-20-2021, 08:02   #4 (permalink)
Member: 2277861
Thanks Meter: 206
try Use version 3.7.1
Page generated in 0.14197 seconds with 8 queries
