07-21-2020, 02:28 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | MFC Suite 3in1 V3.3 Beta Released ! - 2020/7/21 We're very pleased to announce a major new release MFC Suite 3in1 V3.3 Beta This has new features and bugfixes:
Upgrading to new Versions:
Ps. As this is a major new release with many changes, we'll be going for an extended testing phase. There are also some gui fixes which we'll describe in more detail after the release is out. Please try and report issues in this thread to avoid duplicate support issue. Best, The MFC Team |
The Following 7 Users Say Thank You to .::Gsmdenis::. For This Useful Post: |
07-21-2020, 04:06 | #3 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Egypt Age: 37
Member: 710690 Status: Offline Thanks Meter: 907 | lmafo Add support all new Apple iPhone Add support all new Apple Watch Add support all new Apple iPad Add iREWORK and iPOWER X Software inside (We may enable iREWORK and iPOWER X to use iMFC Function in next update) IPR function updated Server side update to support new client 3.3 i think you can support it without tool maybe 3utool |
The Following 3 Users Say Thank You to amrMHF For This Useful Post: |
07-21-2020, 05:34 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 781 | atlast 2 year after the update has begun, our membership has end after the update launch |
The Following User Says Thank You to maxieboy For This Useful Post: |
07-21-2020, 07:30 | #6 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Apple Watch S3, n111sap, Watch3,1 GPS Cellular Restore [info] Using LOCAL IPSW D:\mfc\MFC_Watch3,1_17T530_6.2.1_n111sap_GPS_Cellu lar_Restore_38mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n111sap, Watch3,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 801---------------------- [info] Getting ApNonce in dfu mode... [data] FB47015DC1A8364CF59EFEF0D6DC23237A4458CEC35E2AE97D B68B6B590DE744 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 9A38ED119F2441C0F47191B93162C420588F2138 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting filesystem [info] Found ECID 801--------------- [info] Getting ApNonce in dfu mode... [data] FB47015DC1A8364CF59EFEF0D6DC23237A4458CEC35E2AE97D B68B6B590DE744 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 9A38ED119F2441C0F47191B93162C420588F2138 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (744155 bytes)... [info] Removing USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM:03_SC EP:01_BDID:1C_ECID:001C793228FB00A6_IBFL:3C_SRTG:[IBOOT-2651.0.0.3.3]\{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_17EF&PID_3071\5&3A5E17B4&0&4 [info] Removing USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM:03_SC EP:01_BDID:1C_ECID:001C793228FB00A6_IBFL:3C_SRTG:[IBOOT-2651.0.0.3.3] [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1C_ECID:001C793228FB00A6_IBFL:3 C_SRNM:[FH7VLBJEJ6DW] [info] Adding USB\VID_05AC&PID_1281&MI_01\6&15387D3F&0&0001\{B80 85869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8 004_CPRV:10_CPFM:03_SCEP:01_BDID:1C_ECID:001C79322 8FB00A6_IBFL:3C_SRNM:[FH7VLBJEJ6DW] [info] Noce: fb 47 01 5d c1 a8 36 4c f5 9e fe f0 d6 dc 23 23 7a 44 58 ce c3 5e 2a e9 7d b6 8b 6b 59 0d e7 44 [info] Extracting iBEC.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (744155 bytes)... [info] Removing USB\VID_05AC&PID_1281&MI_01\6&15387D3F&0&0001\{B80 85869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8 004_CPRV:10_CPFM:03_SCEP:01_BDID:1C_ECID:001C79322 8FB00A6_IBFL:3C_SRNM:[FH7VLBJEJ6DW] [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1C_ECID:001C793228FB00A6_IBFL:3 C_SRNM:[FH7VLBJEJ6DW] [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1C_ECID:001C793228FB00A6_IBFL:3 C_SRNM:[FH7VLBJEJ6DW] [info] Adding USB\VID_05AC&PID_1281&MI_01\6&15387D3F&0&0001\{B80 85869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8 004_CPRV:10_CPFM:03_SCEP:01_BDID:1C_ECID:001C79322 8FB00A6_IBFL:3C_SRNM:[FH7VLBJEJ6DW] [info] device serial number is FH7VLBJEJ6DW [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-5540.100.194 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8452 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 048-63982-330.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (14193 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-63982-330.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (77460503 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (120093 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (12686537 bytes)... [info] Removing USB\VID_05AC&PID_1281&MI_01\6&15387D3F&0&0001\{B80 85869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8 004_CPRV:10_CPFM:03_SCEP:01_BDID:1C_ECID:001C79322 8FB00A6_IBFL:3C_SRNM:[FH7VLBJEJ6DW] [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1C_ECID:001C793228FB00A6_IBFL:3 C_SRNM:[FH7VLBJEJ6DW] [info] Waiting for device to enter restore mode... [info] Adding USB\VID_05AC&PID_12AF\F3F427F7CBCA88915D3165BF8CFE 29DB0CF674B9 [info] About to restore device... [info] Waiting for device... [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device f3f427f7cbca88915d3165bf8cfe29db0cf674b9 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 28 [info] ChipID: 32772 [info] UniqueChipID: 8014------------------- [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49157) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] Checking filesystems (15) [erro] Unable to receive message from FDR 0E32FAA8 (-7). 0/2 bytes [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Unmounting filesystems (29) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Sending OOB offset 2193077658, length 1276 [info] Sending OOB offset 0, length 72 [info] Sending OOB offset 2193078422, length 512 [info] Sending OOB offset 0, length 64 [info] Sending OOB offset 2192871361, length 207061 [info] Sending OOB offset 2193077658, length 1276 [info] Sending OOB offset 0, length 72 [info] Sending OOB offset 2193078422, length 512 [info] Sending OOB offset 0, length 64 [info] Sending OOB offset 2192871361, length 207061 [info] Sending OOB offset 0, length 53 [info] Sending OOB offset 162, length 294 [info] Sending OOB offset 53, length 109 [info] Sending OOB offset 456, length 973 [info] Sending OOB offset 53, length 109 [info] Sending OOB offset 162, length 294 [info] Sending OOB offset 0, length 53 [info] Sending OOB offset 152516, length 280425 [info] Sending OOB offset 17536796, length 53204 [info] Sending OOB offset 1975181, length 49714 [info] Sending OOB offset 17599108, length 72159 [info] Sending OOB offset 2193077658, length 1276 [info] Sending OOB offset 0, length 72 [info] Sending OOB offset 2193078422, length 512 [info] Sending OOB offset 0, length 64 [info] Sending OOB offset 2192871361, length 207061 [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checking filesystems (15) [info] Creating Protected Volume (67) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done[info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done[info] Installing DeviceTree (61) [info] Flashing firmware (18) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N111s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 048-63982-330.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 048-63880-311.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating baseband (19) [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [info] Updating Baseband in progress... [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [done] Updating Baseband completed. [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Fixing up /var (17) [info] Modifying persistent boot-args (25) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! Last edited by .::Gsmdenis::.; 07-21-2020 at 07:36. Reason: edit ecid |
The Following 2 Users Say Thank You to .::Gsmdenis::. For This Useful Post: |
07-21-2020, 07:37 | #7 (permalink) |
Freak Poster Join Date: Jul 2009 Location: viet nam
Member: 1067406 Status: Offline Thanks Meter: 5 | still error info] Found device in Recovery mode [info] Identified device as Apple Watch S3, n111bap, Watch3,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [info] device serial number is FH7WL1WNJ6GJ [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 3232830809178150 [info] Getting ApNonce in recovery mode... [data] D68CB4EE0D1DAE1AEFAA28826EFCA18A0DEDA65A6ED76A7383 C83FD942D7B3AA [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] BBEC00F51219F415E56BE8A6137DFD42339D18D4 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting filesystem [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1E_ECID:000B7C3E14000026_IBFL:3 C_SRNM:[FH7WL1WNJ6GJ] [erro] Device is in an invalid state [erro] Unable to find device ECID [done] Operation finished! |
07-21-2020, 07:41 | #8 (permalink) | |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
try to restore it in DFU mode | |
07-21-2020, 08:51 | #12 (permalink) |
Member: 1067406 Status: Offline Thanks Meter: 5 | [done] sending BasebandData [done] Updating Baseband completed. [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Modifying persistent boot-args (25) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] Removing USB\VID_05AC&PID_12AF\AFECA2453EC087D9224305949A7A A0AA0B91BB42 [info] Apple device disconnected! [info] Adding USB\VID_05AC&PID_12AF\AFECA2453EC087D9224305949A7A A0AA0B91BB42 [info] Apple device arrival ... searching USBMux for device after 1s [info] Removing USB\VID_05AC&PID_12AF\AFECA2453EC087D9224305949A7A A0AA0B91BB42 [info] Apple device disconnected! thank you ad DONE |
07-21-2020, 08:52 | #13 (permalink) | |
thanks for your report ! Br., The MFC Team | |
The Following 3 Users Say Thank You to .::Gsmdenis::. For This Useful Post: |
