06-02-2021, 19:36 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: emirates Age: 38
Member: 285020 Status: Offline Sonork: 100.1579574 Thanks Meter: 57 | s3 diag mode error [fixed] [info] Connecting... [erro] Could not find device with ECID:F6951380940A6 in DFU mode! [done] Operation finished! [info] Device present connection uses normal backend [info] Connecting... [erro] Could not find device with ECID:F6951380940A6 in DFU mode! [done] Operation finished! |
06-02-2021, 19:47 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Can you post your steps ? Also your windows environment / iTunes Version / MFC Version | |
06-02-2021, 19:56 | #3 (permalink) |
Member: 285020 Status: Offline Sonork: 100.1579574 Thanks Meter: 57 | [info] Device present connection uses normal backend [info] Connecting... [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [warn] Failed to install usb driver! Error:Other error [info] Current thread priority is 0x0 [info] stage 1, heap grooming ... [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [erro] Exploit failed! [done] Operation finished! |
06-02-2021, 19:59 | #5 (permalink) |
Member: 285020 Status: Offline Sonork: 100.1579574 Thanks Meter: 57 | and some time this error [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [warn] Failed to install usb driver! Error:Other error [erro] libusb_claim_interface error -3 Access denied (insufficient permissions) [erro] Could not find device with ECID:F6951380940A6 in DFU mode! [done] Operation finished! [info] Device present connection uses normal backend [info] Connecting... [warn] Timeout installing driver! [erro] Could not find device with ECID:F6951380940A6 in DFU mode! [done] Operation finished! |
06-02-2021, 20:37 | #8 (permalink) |
Member: 285020 Status: Offline Sonork: 100.1579574 Thanks Meter: 57 | Done DONE DONE DONE [info] Device present connection uses normal backend [info] Connecting... [info] Current thread priority is 0x0 [info] stage 1, heap grooming ... [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [done] Device is now in pwned DFU Mode! [info] Allready installed usb driver. [info] Sending FirstStage [info] Allready installed usb driver. [warn] Failed to install usb driver! Error:Other error [info] Sending commands ... [info] Installing driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227) ! [info] Sending DiagsStage [warn] Failed to install driver! Error:Other error [info] Installing USB driver for device: "Diags CDC Serial" (05AC:1222) ... [warn] Failed to install usb driver! Error:System policy has been modified to reject unsigned drivers Device is allready in Diag Mode but could not determine COM port. Maybe a DCSD cable is required! Please check driver and manually update the driver if required! [done] Operation finished! [warn] Incorrect driver detected! Please wait to update the drivers! [info] Waiting for device arrival (timeout 10.000000 seconds) [erro] Unable to discover device mode. Please make sure a device is attached. [done] Operation finished! [info] Device present connection uses normal backend [info] Installing USB driver for device: "Diags CDC Serial" (05AC:1222) ... [warn] Failed to install usb driver! Error:System policy has been modified to reject unsigned drivers [info] Device is allready in Diag Mode. Please check driver and manually update the driver if required! [done] Operation finished! [info] Opening \\.\COM118 with baudrate 921600 [info] Opening successfull! [info] Reading Model Read: Model Result: MQL02 [info] Reading Serial Number Read: Serial Number Result: ***** [info] Reading Area/Region Read: Area/Region Result: AE/A [info] Reading Bluetooth Address [info] Key: BMac Value: 0x461EAB68 0x00008B35 0x00000000 0x00000000 [info] Reading Ethernet Address [info] Key: EMac Value: 0x461EAB68 0x00008C35 0x00000000 0x00000000 [info] Reading Wifi Address [info] Key: WMac Value: 0x461EAB68 0x00008A35 0x00000000 0x00000000 [info] Reading Logicboard SN. Read: Logicboard SN. Result: **** [info] Reading 'A' Number Read: 'A' Number Result: A1859 [info] Reading Time (RTC) [info] RTC Time: 20210602193400 [info] Done! [info] Writing Serial Number Key SrNm Finished key SrNm! [info] Writing Wifi Address Key WMac Finished key WMac! [info] Done! [info] Writing Bluetooth Address Key BMac Finished key BMac! [info] Done! |
06-04-2021, 09:19 | #12 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2733149 Status: Offline Thanks Meter: 0 | [info] Device present connection uses normal backend [info] Connecting... [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [info] Finshed installing usb driver. [info] Current thread priority is 0x0 [info] stage 1, heap grooming ... [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [info] Finshed installing usb driver. [done] Device is now in pwned DFU Mode! [info] Allready installed usb driver. [info] Sending FirstStage [info] Allready installed usb driver. [info] Sending commands ... [info] Sending DiagsStage [info] Installing USB driver for device: "Diags CDC Serial" (05AC:1222) ... Device is allready in Diag Mode but could not determine COM port. Maybe a DCSD cable is required! Please check driver and manually update the driver if required! [done] Operation finished! i stuck this and i dont know what driver need up date and how ? |
06-04-2021, 10:07 | #13 (permalink) | |
[info] Installing USB driver for device: "Diags CDC Serial" (05AC:1222) ... Device is allready in Diag Mode but could not determine COM port. Maybe a DCSD cable is required! Please check driver and manually update the driver if required! | |
