05-30-2021, 08:39 | #16 (permalink) | |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
You have to check the connections and Use original iPhone USB cable with the newest driver | |
05-30-2021, 09:09 | #17 (permalink) |
Freak Poster Join Date: Mar 2014 Location: lagos
Member: 2147383 Status: Offline Sonork: 12345678 Thanks Meter: 58 | [warn] Please select an valid communication port first! [info] Device present connection uses normal backend [info] Connecting... [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [warn] Failed to install usb driver! Error:Operation timed out [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [warn] Failed to install usb driver! Error:Operation timed out [erro] Could not find device with ECID:1D19D93EFB8026 in DFU mode! [done] Operation finished! [warn] Please select an valid communication port first! |
05-30-2021, 09:25 | #18 (permalink) | |
Strange, can you send your username and teamviewer details to [email protected] , then i can remote check | |
05-30-2021, 17:14 | #19 (permalink) |
No Life Poster Join Date: May 2006 Location: XpErTs GsM ® Age: 41
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | [info] device disconnect... [info] device arrival... found. [info] device disconnect... [info] Device present connection uses normal backend [info] Connecting... [info] Current thread priority is 0x0 [info] stage 1, heap grooming ... [info] stage 2, aquired [erro] Failed to push forward overwrite offset. [info] stage 3, exploit [info] Uploading payload [erro] Exploit failed! [done] Operation finished! Watch is : 3.,4 GPS Model . is this supported ?? Last edited by XpErTsGsM; 05-30-2021 at 17:16. Reason: model |
05-30-2021, 17:17 | #20 (permalink) | |
Overwrite offset means connection not good, usually USB or usb cable problem , Can i know which windows you are using now ? Recommend use win10 64bit | |
06-02-2021, 00:43 | #21 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Colombia
Member: 726741 Status: Offline Thanks Meter: 1,256 | i have this error , support. [info] device arrival... found. [info] device disconnect... [info] Removing USB\VID_05AC&PID_1392\FTL93751K6LLNWLAN [info] Arrival USB\VID_05AC&PID_1392\FTL93751K6LLNWLAN [info] Device present connection uses normal backend [info] Connecting... [info] Current thread priority is 0x0 [info] stage 1, heap grooming ... [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [erro] Exploit failed! [done] Operation finished! |
06-02-2021, 04:05 | #22 (permalink) | |
It's normal , just repeat again https://www.mfcbox.com/tutorials/how...y-mfc-software | |
06-04-2021, 04:33 | #26 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | |
06-05-2021, 18:02 | #28 (permalink) | |
Only mfc software , i don't know what is itools. but you can try by yourself ! here only for mfc software , thanks | |
