Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 06-08-2021, 08:05   #31 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 5,688
@all,
I am glad to see that many of our users have successfully activated watch S3 by MFC New version, Great job :-)
Old 06-09-2021, 02:51   #32 (permalink)
Member: 2705026
Thanks Meter: 15
Originally Posted by .::Gsmdenis::. View Post
@all,
You best for ever ❤️❤️❤️
Old 06-09-2021, 07:58   #33 (permalink)
Amit@'s Avatar
Member: 1988491
Sonork: 100.1653322
Thanks Meter: 311
I got two issue.
First, why sometimes the flash bottom is deactivated? How can i Solve it?
Second, As you see on the uploaded pic, I could not found to how solve the USB Problem
Old 06-09-2021, 08:36   #34 (permalink)
Member: 2985417
i cant connect S3 (try with 3 different working watches) have error
win10 64bit, itunes 12.11.3.17
logs:
Device present connection uses normal backend
Connecting...
Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227).
Failed to install usb driver! Error:Other error
Current thread priority is 0x0
stage 1, heap grooming ...
stage 2, aquired
stage 3, exploit
Uploading payload
Device is now in pwned DFU Mode!
Allready installed usb driver.
Sending FirstStage
Sending commands ...
Unable to connect to device
Error setting boot-args -3
Old 06-09-2021, 09:27   #35 (permalink)
Member: 2985417
from other PC (the same win 10 64 bit, latest itunes, no antivirus)
cant connect
Starting ...
Connecting...
Timeout installing driver!
stage 2, aquired
Failed to push forward overwrite offset.
stage 3, exploit
Uploading payload
Exploit failed!
Operation finished!
Starting ...
Connecting...
stage 2, aquired
stage 3, exploit
Uploading payload
Exploit failed!
Operation finished!
Starting ...
Connecting...
stage 2, aquired
stage 3, exploit
Uploading payload
Could not find device with ECID:CCE820066F26 in DFU mode!
Exploit failed! end
Operation finished!
Starting ...
Connecting...
stage 2, aquired
stage 3, exploit
Uploading payload
Sending FirstStage
Sending DiagsStage
Device not found but should be allready in Diag Mode.
Please check driver and manually update the driver if required or try again!
Operation finished!
Old 06-09-2021, 11:43   #36 (permalink)
Member: 79315
Thanks Meter: 5,688
Operation finished!
then click on USB Device and manually update the CDC driver from C:\MFC\Drivers\UsbSerialDriver(DCSD), Sometime may need disable the driver signature enforcement and then manually update
Old 06-09-2021, 11:44   #37 (permalink)
Member: 79315
Thanks Meter: 5,688
Originally Posted by [email protected] View Post
I got two issue.
you can update the driver by upgrade the itunes
Old 06-10-2021, 07:21   #38 (permalink)
Member: 2985417
It help for me, thanks
Old 06-13-2021, 14:59   #39 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 274
Waiting work in iPhone 6, xr 6s thanks
Old 06-14-2021, 20:44   #40 (permalink)
Member: 79315
Thanks Meter: 5,688
What error you have now ?
Old Yesterday, 09:42   #41 (permalink)
perspolis's Avatar
Member: 60103
Sonork: 108841
Thanks Meter: 1,328
i still have the same problem, it hasnt been solved yet. The drivers are installed completely. Its got problem with windows 10, however i tested the same way with different PC and Laptop therefore the result may be restarting the pc or this error appear as you see on uploaded pic.
i have been struggling with this problem for more than a week.
Old Yesterday, 14:15   #42 (permalink)
Member: 79315
Thanks Meter: 5,688
Try win 10 for the current version ! i am sure win 7 or others will not work
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12547 seconds with 8 queries
