04-07-2022, 10:38 | #16 (permalink) |
Junior Member Join Date: Mar 2005 Age: 39
Member: 132100 Status: Offline Thanks Meter: 3 | [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S0 - 1st generation, n27aap, Watch1,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3.2 [data] Product Build: 15U70 Major: 15 [info] device serial number is FHLQ88PEG9HN [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000006b7ab1b4688 [info] Getting ApNonce in recovery mode... [data] 152C34EF38667C87796C109CCDE4C8D861204644 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [erro] Unable to find required ApSepNonce in parameters [erro] tts>Unable to add img4 tags to TSS request [erro] Unable to get SHSH blobs for this device [done] Operation finished! |
04-07-2022, 12:01 | #17 (permalink) | |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 206 | Quote:
recommend read this then make post https://forum.gsmhosting.com/vbb/14541066-post14.html | |
04-11-2022, 10:39 | #18 (permalink) |
Freak Poster Join Date: May 2012 Location: mumbai
Member: 1754638 Status: Offline Sonork: 100.1614387 Thanks Meter: 22 | after resotre firmware watch s0 can not pair with iphone , what is issue ? asking for update or skip update. if i skip then watch showing unpair |
04-23-2022, 01:46 | #21 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Dominican Republic
Member: 1607116 Status: Offline Sonork: 100.1617729 Thanks Meter: 52 | [info] Using local file C:\Users\Dell\Desktop\watch\0\MFC_Watch1,1_4.3.2_1 5U70_n27aap_Restore_38mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [erro] Unable to connect to device! [erro] i [done] Operation finished! ???? |
04-23-2022, 04:38 | #22 (permalink) | |
