01-24-2018, 17:19 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Please read on software, once you select the EFI option. or can read from here: https://www.mfcbox.com/manual/#features/60 |
01-25-2018, 07:35 | #7 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2429352 Status: Offline Thanks Meter: 72 | it might reach that time or quite more than that time right .if for sure i will get the key 100% no problem i will wait ..what of if it get disconnect or run out of battery and i reconnected again will it resume or start afresh?? |
01-25-2018, 07:54 | #8 (permalink) | |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Recommend connecting your battery charger all the time ! You can disconnect any time as you want, once you disconnect ,you can also do some test for sure the code is running, For example , A, you can take out dongle and open mfc software B, press "read" button [No. 14] as on manual : https://www.mfcbox.com/manual/#features/58 C, read the code logs example "xxxx", to check this "xxxx" if changed Code: "[sett] > Latest Guess at index xx = xxxx" if you don't want make any mistake: E, upto D, take this "xxxx" and input to start value [No. 7] as on manual : https://www.mfcbox.com/manual/#features/58 , F. press "write" [No. 3] and then put dongle back to mac usb continue unlock if 100% ? if the code is 4 digits, i am sure is 100%. Br., | |
01-25-2018, 21:40 | #11 (permalink) |
Member: 2429352 Status: Offline Thanks Meter: 72 | [info] Loading history ... [serv] News: Welcome to our Online Server [info] iDevice module is ready! Please make sure MFC dongle is still connected! [info] > Reading ... [data] > FWVersion is 8 [done] > Latest guess was 3417 format FFFF settings 02 delay 12000 [sett] > settings 02 format FFFF delay 12000ms [sett] > Latest Guess at index 3 = 3415 [data] > (000,0000) (001,0028) (002,0160) (003,3415) [done] OK [info] > Reading ... [data] > FWVersion is 8 [done] > Latest guess was 3417 format FFFF settings 02 delay 12000 [sett] > settings 02 format FFFF delay 12000ms [sett] > Latest Guess at index 3 = 3415 [data] > (000,0000) (001,0028) (002,0160) (003,3415) [done] OK THIS HAVE BEEN THE READ SINCE MORNING THE FIGURE IS NOT CHANGING . I DISCONNECTED WHEN I GET TO OFFICE I RECONNECT TO CONTINUE AND AFTER MORE THAN 15 HOUR I PERFORM READ STILL THE SAME IT NOT WORKING OR WHAT WILL DO NOW |
01-26-2018, 07:01 | #14 (permalink) | |
Code: Latest Guess at index 3 = 3415 | |
01-26-2018, 07:08 | #15 (permalink) |
Member: 2429352 Status: Offline Thanks Meter: 72 | 12seconds is to slow i can i make it 2seconds or even 1seconds to make it faster or what is the effect if i change the real time from 12seconds. I need it to count faster . I guest is from 0000 to 9999 the password will be among this figure right |
