Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 08-15-2022, 14:04   #1 (permalink)
Registered User
Member: 632005
tool MFC not displayed log , help pls
help me
tool runs the program ok, but the displayed text is not there,
I deleted the program and reinstalled it many times
mfc v3.9 not ok
mtc 4.0.1b1
http://www.youtube.com/watch?v=Wnf368HVano
pls
Old 08-15-2022, 15:37   #2 (permalink)
Member: 2277861
Thanks Meter: 206
hello,
Please check C:/mfc/logs file if created
The Following 2 Users Say Thank You to mfcsupport For This Useful Post:
Old 08-16-2022, 04:20   #3 (permalink)
Registered User
Member: 632005
Originally Posted by mfcsupport View Post
hello,
What plans do you have to show on the show?
show the text on the program
Old 08-16-2022, 05:09   #4 (permalink)
Member: 2277861
Thanks Meter: 206
you have not answer what i asked, So I can't identify your problem
Old 08-16-2022, 05:42   #5 (permalink)
Registered User
Member: 632005
hello,
sr bro
log file check ok...
Getting ApNonce in recovery mode... 6E4285AD071F32214FE6F99A8D033C9402EE23E771817268C6 FA3FA806E4374E
tts>Trying to fetch new SHSH blob
Getting SepNonce in recovery mode... 63D4223C06DCB6C323D909ED2EE2191004332439
Unable to find BbCalibrationManifestKeyHash node
Unable to find BbFactoryActivationManifestKeyHash node
Unable to find BbSkeyId node
Sending TSS request...
Request URL set to https://gs.apple.com/TSS/controller?action=2
Sending TSS request attempt 1...
response successfully received
tts>Received SHSH blobs
Using cached filesystem from 'iDeviceTools/MFC_Watch5,3_19U66_8.7_n146sap_/078-33578-073.dmg'
Found ECID 000f6486220b802e
No path for component iBEC in TSS, will fetch from build_identity
Extracting iBEC.n146s.RELEASE.im4p...
Personalizing IMG4 component iBEC...
Tag not processed for iBEC!
Sending iBEC (1165221 bytes)...
Device ecid 000f6486220b802e disconnect detected!
Recovery Mode Environment:
iBoot build-version=iBoot-7459.140.15
iBoot build-style=RELEASE
Sending AppleLogo...
No path for component AppleLogo in TSS, will fetch from build_identity
Extracting applelogo@394~watch.im4p...
Personalizing IMG4 component AppleLogo...
Tag not processed for AppleLogo!
Sending AppleLogo (10138 bytes)...
No path for component ACIBT in TSS, will fetch from build_identity
Extracting BT_FW_m9.im4p...
Personalizing IMG4 component ACIBT...
Tag not processed for ACIBT!
Sending ACIBT (1846417 bytes)...
No path for component ACIWIFI in TSS, will fetch from build_identity
Extracting wifi_armv7r_m9_rtkit_image.im4p...
Personalizing IMG4 component ACIWIFI...
Tag not processed for ACIWIFI!
Sending ACIWIFI (1906601 bytes)...
No path for component ANE in TSS, will fetch from build_identity
Extracting h11_ane_fw_mercury.im4p...
Personalizing IMG4 component ANE...
Tag not processed for ANE!
Sending ANE (1731605 bytes)...
No path for component AOP in TSS, will fetch from build_identity
Extracting aopfw-watch5aop.im4p...
Personalizing IMG4 component AOP...
Tag not processed for AOP!
Sending AOP (2071701 bytes)...
No path for component GFX in TSS, will fetch from build_identity
Extracting armfw_g11m.im4p...
Personalizing IMG4 component GFX...
Tag not processed for GFX!
Sending GFX (897469 bytes)...
No path for component RestoreTrustCache in TSS, will fetch from build_identity
Extracting 078-33402-075.dmg.trustcache...
Personalizing IMG4 component RestoreTrustCache...
Sending RestoreTrustCache (16754 bytes)...
No path for component SCE in TSS, will fetch from build_identity
Extracting scefw.im4p...
Personalizing IMG4 component SCE...
Tag not processed for SCE!
Sending SCE (20173 bytes)...
No path for component SIO in TSS, will fetch from build_identity
Extracting SmartIOFirmware_ASCv2.im4p...
Personalizing IMG4 component SIO...
Tag not processed for SIO!
Sending SIO (1176673 bytes)...
No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity
Extracting WirelessPower.watch4.im4p...
Personalizing IMG4 component WCHFirmwareUpdater...
Tag not processed for WCHFirmwareUpdater!
Sending WCHFirmwareUpdater (31860 bytes)...
No path for component RestoreRamDisk in TSS, will fetch from build_identity
Extracting 078-33402-075.dmg...
Personalizing IMG4 component RestoreRamDisk...
Tag not processed for RestoreRamDisk!
Sending RestoreRamDisk (88987800 bytes)...
No path for component RestoreDeviceTree in TSS, will fetch from build_identity
Extracting DeviceTree.n146sap.im4p...
Personalizing IMG4 component RestoreDeviceTree...
Sending RestoreDeviceTree (44361 bytes)...
No path for component RestoreSEP in TSS, will fetch from build_identity
Extracting sep-firmware.n146s.RELEASE.im4p...
Personalizing IMG4 component RestoreSEP...
Sending RestoreSEP (5479806 bytes)...
No path for component RestoreKernelCache in TSS, will fetch from build_identity
Extracting kernelcache.release.watch5...
Personalizing IMG4 component RestoreKernelCache...
Sending RestoreKernelCache (13479465 bytes)...
About to restore device...
Waiting for device...
device 607f1933106b6c15da0785b7e110a9113809ec2e is not in restore mode
Device is now connected in restore mode...
Connecting now...
Connected to com.apple.mobile.restored, version 15
Device 00008006-000F6486220B802E has successfully entered restore mode
Hardware Information:
BoardID: 20
ChipID: 32774
UniqueChipID: 4332651910234158
ProductionMode: true
Previous restore exit status: 0x100
Starting FDR listener thread
Connecting to FDR client at port 1082
About to do ctrl handshake
Ctrl handshake done (ConnPort = 49159)
Requesting NOT TO Update Baseband
Checkpoint 1621 complete with code 0
Checkpoint 1540 complete with code 0
Checkpoint 1679 complete with code 0
About to send RootTicket...
Sending RootTicket now...
Done sending RootTicket
Checkpoint 1547 complete with code 0
Waiting for NAND (28)
Checkpoint 1549 complete with code 0
Updating NAND Firmware (58)
Checkpoint 1550 complete with code 0
Checkpoint 1551 complete with code 0
Checkpoint 1628 complete with code 0
Checkpoint 1552 complete with code 0
Checkpoint 1555 complete with code 0
Checkpoint 1662 complete with code 0
Sending NORData...
Found firmware path Firmware/all_flash
zip_name_locate: Firmware/all_flash/manifest
Getting firmware manifest from build identity
Extracting LLB.n146s.RELEASE.im4p...
Personalizing IMG4 component LLB...
Tag not processed for LLB!
Extracting dali-ui.n146s.release.im4p...
Personalizing IMG4 component Dali...
Tag not processed for Dali!
Personalizing IMG4 component DeviceTree...
Tag not processed for DeviceTree!
Extracting recoverymode@394~watch.im4p...
Personalizing IMG4 component RecoveryMode...
Tag not processed for RecoveryMode!
Extracting iBoot.n146s.RELEASE.im4p...
Personalizing IMG4 component iBoot...
Tag not processed for iBoot!
Personalizing IMG4 component SEP...
Tag not processed for SEP!
Sending NORData now...
Done sending NORData
Checkpoint 1545 complete with code 0
Checkpoint 1683 complete with code 0
Unmounting filesystems (29)
Checkpoint 1637 complete with code 0
Checkpoint 1556 complete with code 0
Checkpoint 1686 complete with code 0
Checkpoint 1699 complete with code 0
Checkpoint 1695 complete with code 0
Checkpoint 1620 complete with code 0
Checkpoint 1687 complete with code 0
Checkpoint 1557 complete with code 0
About to send FDR Trust data...
Sending FDR Trust data now...
sending FDR Trust Data
Checkpoint 1558 complete with code 0
Checkpoint 1559 complete with code 0
Checkpoint 1560 complete with code 0
Checking for uncollected logs (44)
Checkpoint 1561 complete with code 0
Checkpoint 1562 complete with code 0
Checkpoint 1563 complete with code 0
Checkpoint 1633 complete with code 0
Checkpoint 1565 complete with code 0
Checkpoint 1614 complete with code 0
Checkpoint 1567 complete with code 0
Checkpoint 1674 complete with code 0
Creating partition map (11)
Checkpoint 1569 complete with code 0
Checkpoint 1632 complete with code 0
Checkpoint 1570 complete with code 0
Checkpoint 1629 complete with code 0
Checkpoint 5645 complete with code 0
Creating filesystem (12)
Checkpoint 1624 complete with code 0
Checkpoint 1625 complete with code 0
Checkpoint 1626 complete with code 0
About to send filesystem...
Connected to ASR
Validating the filesystem
Filesystem validated
Sending filesystem now...
sending filesystem
Operation: Verifying restore (14)
Checkpoint 1627 complete with code 0
Checkpoint 1664 complete with code 0
Checkpoint 1653 complete with code 0
Checkpoint 1676 complete with code 0
Checking filesystems (15)
Mounting filesystems (16)
Checkpoint 1574 complete with code 0
Checkpoint 1634 complete with code 0
Checkpoint 1655 complete with code 0
Checkpoint 1658 complete with code 0
Checkpoint 1575 complete with code 0
Checkpoint 1690 complete with code 0
Checkpoint 1691 complete with code 0
Checkpoint 1618 complete with code 0
Checkpoint 1588 complete with code 0
Checkpoint 1661 complete with code 0
Operation: Unknown operation (80)
Sending IsiBootEANFirmware image list
Sending IsiBootNonEssentialFirmware image list
Flashing firmware (18)
Checkpoint 4864 complete with code 0
Sending IsEarlyAccessFirmware image list
Checkpoint 4882 complete with code 0
Operation: Requesting FUD data (36)
Found IsFUDFirmware component ACIBT
Found IsFUDFirmware component ACIWIFI
Found IsFUDFirmware component ANE
Found IsFUDFirmware component AOP
Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata
Found IsFUDFirmware component GFX
Found IsFUDFirmware component LeapHaptics
Found IsFUDFirmware component Multitouch
Found IsFUDFirmware component RTP
Found IsFUDFirmware component RestoreTrustCache
Found IsFUDFirmware component SCE
Found IsFUDFirmware component SIO
Found IsFUDFirmware component StaticTrustCache
Found IsFUDFirmware component SystemVolume
Sending IsFUDFirmware image list
Sending IsFUDFirmware for ACIBT...
Sending IsFUDFirmware for ACIWIFI...
Sending IsFUDFirmware for ANE...
Sending IsFUDFirmware for AOP...
Extracting 078-33578-073.dmg.mtree...
Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata...
Tag not processed for Ap,SystemVolumeCanonicalMetadata!
Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata...
Sending IsFUDFirmware for GFX...
Extracting N146S_LeapHapticsFirmware.im4p...
Personalizing IMG4 component LeapHaptics...
Tag not processed for LeapHaptics!
Sending IsFUDFirmware for LeapHaptics...
Extracting N146s_Multitouch.im4p...
Personalizing IMG4 component Multitouch...
Tag not processed for Multitouch!
Sending IsFUDFirmware for Multitouch...
Extracting rtpfw.im4p...
Personalizing IMG4 component RTP...
Tag not processed for RTP!
Sending IsFUDFirmware for RTP...
Sending IsFUDFirmware for RestoreTrustCache...
Sending IsFUDFirmware for SCE...
Sending IsFUDFirmware for SIO...
Extracting 078-33578-073.dmg.trustcache...
Personalizing IMG4 component StaticTrustCache...
Tag not processed for StaticTrustCache!
Sending IsFUDFirmware for StaticTrustCache...
Extracting 078-33578-073.dmg.root_hash...
Personalizing IMG4 component SystemVolume...
Tag not processed for SystemVolume!
Sending IsFUDFirmware for SystemVolume...
Checkpoint 4874 complete with code 0
Updating gas gauge software (47)
Checkpoint 4865 complete with code 0
Checkpoint 4866 complete with code 0
Updating Stockholm (55)
Checkpoint 4868 complete with code 0
Checkpoint 4868 complete with code 18446744073709551615
Checkpoint 1589 complete with code 56
Checkpoint 1659 complete with code 56
Checkpoint 1660 complete with code 0
Checkpoint 5651 complete with code 0
Checkpoint 1607 complete with code 0
Status message: Ramrod firmware update failed.
Hint: The display of this model is not compatible, or you can replace the NFC module
Log is available in ErrorLog.plist
Unable to successfully restore device
Checkpoint 1608 complete with code 0
Unable to restore device
Failed
Operation finished!
Old 08-16-2022, 05:59   #6 (permalink)
Member: 2277861
Thanks Meter: 206
try reinstall C:\MFC\Drivers\MicrosoftRedistributables both driver , if the logs still did not show , you need check your windows OS, thanks
The Following User Says Thank You to mfcsupport For This Useful Post:
Page generated in 1.08628 seconds with 8 queries
