Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Junior Member ![]() Join Date: Jul 2014
Member: 2220206 Status: Offline Sonork: 100.1625182 Thanks Meter: 0 | Unable to Repair Error 1110 on iPhone 6s Plus iOS15 I have tried millions time to repair error 1110 for iPhone 6s plus version ios15. But it gets stuck on restore mode with small progress bar. Any assistance will be appreciated. I have also attached the log and status of my Phone. I have also tried to update many time, still no luck. |
![]() | #3 (permalink) | |
Member: 2220206 Status: Offline Sonork: 100.1625182 Thanks Meter: 0 | Quote:
Please check the log: [info] Using LATEST available IPSW. [info] Updated version data. [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as iPhone 6s Plus, n66map, iPhone8,2 [info] Latest firmware is iPhone_5.5_15.7.3_19H307_Restore.ipsw [info] Verifying 'iDeviceTools/iPhone_5.5_15.7.3_19H307_Restore.ipsw'... [info] Checksum matches. [info] Extracting BuildManifest from ipsw [data] Product Version: 15.7.3 [data] Product Build: 19H307 Major: 19 [info] device serial number is F2QQKHZDGRWM [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 0012344430526c26 [info] Getting ApNonce in recovery mode... [data] 5F71C24CAA5B38A9D7E36294A9C42EE844247C2D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 00904D6D44F2E8AD7B267E65510CEC8C28E9BFBB [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/iPhone_5.5_15.7.3_19H307_Restore/098-68819-009.dmg' [info] Found ECID 0012344430526c26 [info] Getting ApNonce in recovery mode... [data] 5F71C24CAA5B38A9D7E36294A9C42EE844247C2D [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 00904D6D44F2E8AD7B267E65510CEC8C28E9BFBB [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n66m.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (452682 bytes)... [info] Device ecid 0012344430526c26 disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-7459.140.15 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting [email protected]~iphone.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (19386 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 098-68739-009.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (11421 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 098-68739-009.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (116005911 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n66map.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32261 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n66m.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (3221753 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.n66... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (20842840 bytes)... [info] Device ecid 0012344430526c26 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device ffffffffffffffffffffffffffffffff000001b3 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 6 [info] ChipID: 32771 [info] UniqueChipID: 5124017053920294 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1679 complete with code 0 [info] Checkpoint 1544 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Updating NAND Firmware (58) [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checkpoint 1662 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n66m.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting [email protected]~iphone.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting [email protected]~iphone.im4p... [info] Personalizing IMG4 component BatteryCharging0... [info] Extracting [email protected]~iphone.im4p... [info] Personalizing IMG4 component BatteryCharging1... [info] Extracting [email protected]~iphone.im4p... [info] Personalizing IMG4 component BatteryFull... [info] Extracting [email protected]~iphone.im4p... [info] Personalizing IMG4 component BatteryLow0... [info] Extracting [email protected]~iphone.im4p... [info] Personalizing IMG4 component BatteryLow1... [info] Extracting [email protected]~iphone-lightning.im4p... [info] Personalizing IMG4 component BatteryPlugin... [info] Extracting DeviceTree.n66map.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting [email protected]~iphone-lightning.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n66m.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n66m.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n66m.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 1545 complete with code 0 [info] Checkpoint 1683 complete with code 0 [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Checkpoint 1637 complete with code 0 [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1686 complete with code 0 [info] About to send BuildIdentity Dict... [info] Sending BuildIdentityDict now... [info] Done sending BuildIdentityDict [info] Checkpoint 1699 complete with code 0 [info] Checkpoint 1695 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1687 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 4294968856 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 4294968857 complete with code 0 [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] Checkpoint 1562 complete with code 0 [info] Connecting to FDR client at port 49158 [info] Checkpoint 4294968859 complete with code 0 [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 38654707229 complete with code 0 [info] Checkpoint 4294968910 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1674 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Checkpoint 5645 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [erro] Unable to receive data from ASR [erro] Unable to receive validation packet [erro] Please delete filesystem file name 'iDeviceTools/iPhone_5.5_15.7.3_19H307_Restore/098-68819-009.dmg' from disk and try again! [erro] ASR was unable to validate the filesystem [erro] Unable to send filesystem [erro] Unable to successfully restore device [info] About to send BuildIdentity Dict... [info] Sending BuildIdentityDict now... [info] Done sending BuildIdentityDict [info] Cleaning up... [done] Done [done] Operation finished! | |
