11-19-2021, 17:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: Mexico
Member: 985126 Status: Offline Sonork: 100.1626690 Thanks Meter: 199 | I can't put it in diag mode [info] Connecting... [info] Device present in DFU mode using normal backend [info] Current thread priority is 0x0 [info] stage 1, heap grooming ... [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [erro] Exploit failed! |
11-20-2021, 02:36 | #2 (permalink) |
Member: 985126 Status: Offline Sonork: 100.1626690 Thanks Meter: 199 | [data] ProductType:Watch3,4 [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [done] Operation finished! [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [done] Operation finished! [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [done] Operation finished! [info] Activate or deactivate a device. [done] Operation finished! [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [done] Operation finished! [info] Using LOCAL IPSW C:\Users\DR PHONE RECEPCION\Downloads\MFC\SERIE 3 42MM GPS\MFC_Watch3,4_8.1_19R570_n121bAP_GPS_Restore_42 mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 8.1 [data] Product Build: 19R570 Major: 19 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000611410e288026 [info] Getting ApNonce in dfu mode... [data] 39B7E37F7DFDCE37520AE7B79B54D64C05A157B1983EB542C1 FEFA8C640D3AD4 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 2EC1054276BD5DCD45A149DA2B1E02219DF6D037 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_8.1_19R570_n121bAP_GPS_Restore_42mm/018-59188-082.dmg' [info] Found ECID 000611410e288026 [info] Getting ApNonce in dfu mode... [data] 39B7E37F7DFDCE37520AE7B79B54D64C05A157B1983EB542C1 FEFA8C640D3AD4 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 2EC1054276BD5DCD45A149DA2B1E02219DF6D037 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (769060 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000611410e288026 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [info] device serial number is GJ9ZT9BLJ5X6 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [erro] Unable to find required ApSepNonce in parameters [erro] tts>Unable to add img4 tags to TSS request [erro] Unable to get SHSH blobs for this device [erro] Unable to place device into recovery mode from Recovery mode [done] Operation finished! |
11-20-2021, 02:37 | #3 (permalink) |
Member: 985126 Status: Offline Sonork: 100.1626690 Thanks Meter: 199 | [erro] Unable to find required ApSepNonce in parameters [erro] tts>Unable to add img4 tags to TSS request [erro] Unable to get SHSH blobs for this device [erro] Unable to place device into recovery mode from Recovery mode |
