02-25-2017, 23:26 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | this thread may be can help you http://forum.gsmhosting.com/vbb/f937...-done-2168625/ and also check the capacitor value near the nand ic |
The Following User Says Thank You to maxieboy For This Useful Post: |
02-25-2017, 23:44 | #4 (permalink) | |
Insane Poster Join Date: Feb 2017
Member: 2685790 Status: Offline Thanks Meter: 21 | Quote:
I have a couple iPad mini nand I pulled off of dead boards. Do i cope over boot1 ce1 & boot 2 ce2 to new nand? And one more thing. I was told error 40 is also caused from nand not attached or bad reball is this true? Sorry for so many questions. Thank you for answering back. | |
02-25-2017, 23:50 | #5 (permalink) | ||
Member: 2685790 Status: Offline Thanks Meter: 21 | [ Quote:
This is after nand take off and cleaning. | ||
02-26-2017, 12:12 | #6 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1803458 Status: Offline Thanks Meter: 8 | At first not need any ip box or another, just working NAND from 5S 6 air air 2. From mini 1 i dont know for sure, i think it will also work but without serial number. |
The Following User Says Thank You to GPU5970 For This Useful Post: |
02-26-2017, 19:07 | #9 (permalink) |
Member: 302596 Status: Offline Thanks Meter: 784 | try to change new hdd without touch the kernel. just program to itunes and if success put the serial number on new hdd and restore again post result |
02-27-2017, 23:26 | #10 (permalink) |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | I also still have error 40. 100% not board damage because i restored with a good nand from china.... But if i put my own nand in with changed serial. Error 40... I tested it before changing the serial so it is for sure the ip box that does something wrong with the 64 bit units. Followed maxieboy steps but doesnt solve anything.. |
The Following User Says Thank You to timvandenboo For This Useful Post: |
03-03-2017, 10:40 | #12 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | I have been working with IPbox for sometime now. And have realized that Ipbox has the capability to write sn and all other information without apple firmware in nand. Previously even i used to erase the chip and directly write the required information. It would obviously write the S/n and other information. But when you try to restore the phone you will be prompted with error 40. what i have realized is that this is a 2 step process. First we need to save the info from the chip Then erase the whole chip. Now reball and solder back to the phone. Restore the phone. (phone will be perfectly restored but you wont be able to activate it) Now Desolder the Nand once again and write the S/N on it. Solder it back. Done. (No need to restore it again) Now you can perfectly activate and use the phone. Hope this helps someone. |
The Following 4 Users Say Thank You to CDMA_RASHID For This Useful Post: |
03-03-2017, 16:05 | #13 (permalink) | |
Freak Poster Join Date: Jun 2012 Location: Canada
Member: 1773784 Status: Offline Thanks Meter: 27 | Quote:
The Following 2 Users Say Thank You to satglitch For This Useful Post: |
03-07-2017, 03:20 | #15 (permalink) | |
Okay it restored with iTunes What do I do now? Take nand off and just write sn? Do I enter my own sn and hit fix invalid serial number? | |
The Following User Says Thank You to Albo221 For This Useful Post: |
