Finally! Solution for ipad 2 wifi dual nand!!! i search it many times,and i cant find answer UNTIL TODAY!! if you have EMC 2415 DUAL NAND ipad 2 you need to remove BOTH nands and you will need to replace the second one with iphone 4s nand...(i have used TOSHIBA THGVX1G7D2GLA08) please read it again before ask any question,NOT IPHONE 4 NAND,you need 4S NAND and you will need to put it away from CPU like this http://images.anandtech.com/doci/428...ad2ifixit.jpegif you put it near to cpu it will not work in my case for a reason i cant understand,i try to restore it via 3utools first and i got INVALID SN ERROR,after this i try it with itunes and the ipad successfully restored BUT after restore i need to activate it with 3uTools please do it yourself and post your results also please not what type of nand you used for it |
Good work.. Can you share with us how did you programmed new information using ipbox2? Thanks for sharing your experiences Sent from my SM-N9005 using Tapatalk |
as i said you need iPhone 4s NAND,i use 16GB TOSHIBA THGVX1G7D2GLA08 1st i select ERASURE ALL 2nd i select iPad 2 3rd insert the SN 4th Write 5th FIX Invalid SN(optional,on some users may not needed but i did it anyway) |
old story, you can use any 32 bit nand if you know |
for this reason i open this topic,because after a lot of searching i see many users with the same problems |
if you know ? control the solution you can control the competition |
Ipad2 i have ipad 2 duall ic how to upgread 64gb memory 16gb new plus 32gb k9pfg08u5m-lcbo old but show only 16gb on ipad put old nand 32 + 32 error 9 help me |
I have same problem ,no sn number .dont know why,should fix sn? Will try tomorrow,thank you share . |
Hello please HELP here... give me the Solution !! after remove two nand and place toshiba NAND i got error 9.. Nand place far from CPU ! |
Same problem, i changed for other nand and cheked, after erase all that not really erased |
ipad 2 error 40 Using original nand removed from ipad 2 they nand is not deduct jcid pro1000s so i taken nand from iphone 4s and programmed using jcid pro1000s but result after restore i got error 40..... any one help for the solution |
