08-03-2016, 08:55 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: china guangzhou Age: 35
Member: 812359 Status: Offline Sonork: 100.1597111 Thanks Meter: 6,791 | how to repair Iphone & Ipad Memory IC with IP BOX V2 First,use NAND ID Test function read Memory IC Chip info then,Erase Full Flash Erase Flash done Write Back your SN and others info to the memery disk again |
The Following 11 Users Say Thank You to zhulianqi For This Useful Post: |
08-04-2016, 07:14 | #3 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | This is IPBOX V2 ...The Most Wanted Product to Repair APPLE Set. If Others Product can't Change Serial Number ( SN ) the Iphone & Ipad New Memory IC. Do not Judge that IC has Damage !!! It's Work !!, Just use IPBOX V2 ...Make it alive and Working again!! as we know WL Tool has High Price , did you know??? but WL Tool can't write SN of Apple set BUT..... IPBOX V2 can ERASE - FLASH and make it alive and working again IPBOX TEAM Safe you again !!! as we know and you can see ....Price of Iphone Memory Chip is VERY HIGH. You need spend Much Money ( 50 USD ) , but as you know need GAMBLING for that ( means that ic tested or NOT !! ) That my explanation Hope you understand my words and .... Have a Nice day !!! Regard, ARD . |
The Following 12 Users Say Thank You to .::ARD::. For This Useful Post: |
08-04-2016, 21:14 | #4 (permalink) |
Freak Poster Join Date: Feb 2012 Location: Lebanon
Member: 1726910 Status: Offline Sonork: 100.1623945 Thanks Meter: 41 | how to repair Iphone & Ipad Memory IC with IP BOX V2 WL tool can write apple SN for sure but it's more expansive! But what about repairing dead IC? What about reading fingerprint ic for iphone 6G ? Sent from my iPhone using Tapatalk |
The Following User Says Thank You to janzir For This Useful Post: |
08-04-2016, 22:10 | #5 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48755 Status: Offline Thanks Meter: 30 | hi guys, just bought a new IPBox V2, and downloaded the v2.6. Now i tried to repair 5 NAND 5c 32GB detected OK 5c 16GB NAND unrecognized 5s detected ok 6 detected ok 6+ detected ok However, I always have an error abour CE2, and many other read/write errors with all the NAND i used. See picture below. What is the issue? Last edited by haddar; 08-04-2016 at 22:18. |
The Following 2 Users Say Thank You to haddar For This Useful Post: |
08-04-2016, 22:16 | #6 (permalink) |
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Try to erase in the Nand flash tab Whats the result Last edited by .::ARD::.; 08-04-2016 at 22:25. |
The Following User Says Thank You to .::ARD::. For This Useful Post: |
08-04-2016, 22:30 | #8 (permalink) |
Member: 48755 Status: Offline Thanks Meter: 30 | It doesn't help much when erasing all content from CE2, it says error for all blocks from 0x0000000 till i stop it |
The Following User Says Thank You to haddar For This Useful Post: |
08-05-2016, 06:01 | #11 (permalink) |
Member: 812359 Status: Offline Sonork: 100.1597111 Thanks Meter: 6,791 | [QUOTE=haddar;11965874]It doesn't help much when erasing all content from CE2, it says error for all blocks from 0x0000000 till i stop it Connect my sonork please!!!1000.1597111 or wehcat:008613631320431 |
08-06-2016, 00:19 | #14 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Madrid
Member: 1898289 Status: Offline Thanks Meter: 39 | Hi, is possible to take the HDD data (pictures, contacts, etc..) reading direct from Nand for example in the iPhone is dead? Enviado desde mi HTC One mediante Tapatalk |
