12-23-2016, 03:57 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: china guangzhou Age: 35
Member: 812359 Status: Offline Sonork: 100.1597111 Thanks Meter: 6,791 | how to solve iphone 64bit flash with itunes error 40 and after erase all do not do any think in ip box any more just reput in the iphone pcb after flash with ios 10.2 after flash done,you can see not sn then repair sn by ip box softwre IOS10 is diffenct and ios9 now But Error 40 not 100% nand flash,you must be see when error 40 mobile Progress bar where is it going!!! if mobile Progress bar just come and not start,then is nand flash if Progress bar going a little,maybe is cpu or nand Peripheral capacitance resistance Last edited by zhulianqi; 12-23-2016 at 04:07. |
The Following 11 Users Say Thank You to zhulianqi For This Useful Post: |
12-25-2016, 12:49 | #3 (permalink) |
Freak Poster Join Date: Feb 2016 Location: globalworld
Member: 2532019 Status: Offline Thanks Meter: 20 | hi, so no need extraction disk data??? this work for original nand ic ??? how about 6+ change nand do i need the back data from extraction or same procedure??? |
12-29-2016, 08:05 | #5 (permalink) |
Junior Member Join Date: Feb 2014 Location: United Arab Emirates
Member: 2134743 Status: Offline Thanks Meter: 13 | ipad error 40 ipad error 40 when occured in itune after nand sn change restart yours pc try again if the problem same like before the nand is damage try another nand your problem will be solve |
12-29-2016, 12:48 | #6 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
after back up and format to ipbox2 becomes error 40 im pretty sure that this is not a nand ic issue, the phone is working and i check any posible problem for error 40 but all is okay. i have 10 iphone 6 plus the same problem error 9 after do some format on ipbox 2 it will become error 40 im planing to buy WL tools | |
12-29-2016, 13:17 | #7 (permalink) |
Member: 302596 Status: Offline Thanks Meter: 784 | do not do erase all without back all details of your phone, i have problem now in my 1 iphone 6 plus i fallow the procedure above and i lost all details of nand ic after you arase all? all details will also delete e.g sn,wifi,board ic, etc, so how you can transfer from another nand if you dont know your sn and other details from old ic ? |
The Following User Says Thank You to maxieboy For This Useful Post: |
01-02-2017, 23:32 | #10 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2618186 Status: Offline Thanks Meter: 2 | Greetings friends, I also like 4 iphone with error 40 in ituns some solution? I could not get the most out of my ip box v2 |
The Following User Says Thank You to jcgriman For This Useful Post: |
01-17-2017, 20:40 | #12 (permalink) |
Freak Poster Join Date: Jan 2013 Location: socal
Member: 1866487 Status: Offline Thanks Meter: 113 | This box does NOT work on newer devices, 100% tested by me. I do ALOT of hardware repair, especially touch IC chip replacement and power IC replacement also ALOT of MacBook EFI lock removal and for EFI sometimes needs to be desoldered from logic board, programmed and soldered back on, I've done it at least 40+ times and NEVER an issue with over heating and damaging the chip, not one OK......I've had IP BOX for about a month and I have 6 iPad mini 4 2 iPad mini 3 a few iPad air 2 and iPad 4 ALL error 40 in iTunes...i have SHP with universal PCB holder which eliminates the need for high temp hot air gun..This box has ZERO support and someone needs to pull this product because support has either NOT giving correct guide OR it does not work. I've followed all threads in IP BOX forum and all the same error 40, on older devices it's OK but no one is trying to remove iCloud on 1st ipads lol Sent from my Pixel XL using Tapatalk |
The Following 3 Users Say Thank You to dam1inc For This Useful Post: |
01-27-2017, 11:04 | #15 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1665307 Status: Offline Thanks Meter: 3 | Okéy Guys, I did an repair on iphone 6, with error 40. so first what i was thinking it is the HDD NAND. So I did soft rehot and the did the restore in itunes and it went fine. All worked ok. Until few minutes the phone turn it self of and back in DFU mode. restore back error 40 again. So i was thinking it has to do with the cpu. The phone worked fine before, when i did u2 ic replacment then the error 40 showed up. |
The Following User Says Thank You to reparatieplus For This Useful Post: |
