Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > IP-BOX (The SMART Tool)
Old 12-01-2016, 11:44   #91 (permalink)
Member: 2648864
Originally Posted by charletan View Post
its regular 5v dommagad remplace new one
did not help this ((
Old 12-08-2016, 17:31   #92 (permalink)
Member: 2437111
boa ferramenta, é possível descobrir o e-mail ou telefone do antigo dono?
Old 12-12-2016, 17:35   #93 (permalink)
Member: 2629557
Thanks Meter: 5
After plenty of research I decided to buy ip box as it looked great and seemed to have good support on here but after getting it and getting error 40 after programming nand and seeing others getting the same I'm really disappointed to be getting no support or guidance and others are having the same problem since update 5.1. Can anyone help or respond or have I wasted my money
Old 02-21-2017, 04:20   #94 (permalink)
Member: 2687264
i have it but i don't know how to get softwear, and it's driver, i plug it to my computer but fail conect
Old 03-12-2017, 22:42   #95 (permalink)
Member: 499918
Thanks Meter: 2
why getting this error when make extaction disk data???
>> Is reading Nand_Flash information...
Nand_ID : 0x50504E010508
Nand_EXTEND_ID : 0x4582604C5804
Nand_Information: 052226P_SD_TLC2P
Nand_Factory : SanDisk
Nand_Name : SDMILBCF4_064G
Nand_PAGE : 268
Nand_PAGE_Size : 16448
Nand_ECC_Size : 64
Nand_CE_Number : 2
Nand_PLANE_Count: 4
Nand_Capacity : 73843888128Byte/70423MB/68.42GB
>>> Sorry !!! Not know hard disk boot, the underlying have been erased !!!
Old 03-17-2017, 15:53   #96 (permalink)
Member: 2696534
Je cherche boite de flash
Old 03-21-2017, 00:52   #97 (permalink)
Member: 2437111
Good evening, does anyone have a charging cable from the iphone 4 unlock ipbox to sell me? Or could you give me a quote that sells the cable?
[email protected]
Old 03-21-2017, 00:57   #98 (permalink)
Member: 2437111
Good evening, I have an ipbox and I need the charging cable for 4, 4s, does anyone have to sell me? Or could you let me know a quote for me to buy?
Old 03-21-2017, 06:08   #99 (permalink)
Member: 1991639
No need to bother anyone but any news if any....
when they will be adding support for iphone 6s / 6s+ for serial number change?
Old 03-23-2017, 19:18   #100 (permalink)
Member: 1569428
Thanks Meter: 2
With this tool(ip box v2) can I use it on erase and rewrite A9 CPU IC info?
Old 03-30-2017, 00:13   #101 (permalink)
Member: 2654307
Thanks Meter: 4
Hello
** I really dno't know where to post this query to receive a reply, so I copied this post in some threads. The question is, can we expect some new software update that brings support for some NAND's that has been detected have no support?, if the answer is yes, will it be soon?, I'm querying this because I have some of these NANDs decorating my desktop without possibility of being used.
One of this NAND is the toshiba THGBX4G8D4LLDYC
other is SK hynix model H2JTDG8UD1BMR
* Sincerely
Old 07-24-2017, 14:34   #102 (permalink)
Member: 2731871
bonjour pouvez vous m'aider a me connecté a ma ip box 2 si vous plait merci
Old 07-28-2017, 20:00   #103 (permalink)
Member: 2731871
bonjour pouvez vous m'aider a mes connecter a ma ip box 2 ci vous plait?
Old 08-01-2017, 13:09   #104 (permalink)
Member: 2742915
Je cherche le lien pour la nouvelle version pour ma ip box
Le lien c'est ver5.2
Quelqu'un a sa svp
The Following User Says Thank You to jessicadubois For This Useful Post:
Old 01-26-2018, 11:02   #105 (permalink)
Member: 2751356
how should we repair 6 4013 error
Page generated in 0.24591 seconds with 8 queries
