05-16-2017, 14:44 | #1 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1900520 Status: Offline Thanks Meter: 4 | iPad mini No wifi after SN change |
05-16-2017, 15:39 | #3 (permalink) |
Member: 1900520 Status: Offline Thanks Meter: 4 | sorry can you explain? i have changed wifi address to working iphone 5 address now and still not working. why would i need to change wifi ic? you mean its faulty or you mean everytime i change SN i have to change wifi ic aswel? |
05-17-2017, 14:55 | #5 (permalink) |
Member: 1900520 Status: Offline Thanks Meter: 4 | i have done that but still no wifi, im not having much luck this week... i have now moved onto a ipad mini 2 and getting 4014 error 100% connected correctly, am using nand test cable |
05-19-2017, 05:11 | #6 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
In my case error 4014 was caused by not attaching all the cables to the mail board. The nature of the error is bad connectivity somewhere from the USB connection down to the main board. After that I got an error 40, but I solved that one by not using the ribbons. I had some luck with them a few times when they work, but after checking every pad solder and they look ok I go straight to main board. | |
