Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > IP-BOX (The SMART Tool)
Old 01-20-2021, 21:47   #1 (permalink)
Member: 2263638
Thanks Meter: 3
Question iPad Air 2 - activation error - with a8 serial
Hi,
I have an activation problem for iPad air 2 a1566 wifi only
I have A8 serial , wifi and bt...
They work with Toshiba 128gb nand, succesfully activated
But 2 of them have sandisk nand 64/32gb
First time in 3utools serial was not available.
I erase all put all info and write again.
Error still the, iPad can’t be activated. Sn WiFi and bt are in the place...
Tested with ip studio box and ip box
Bad boot? Bad nand? Bad data?
Thanks!
Stefan
The Following User Says Thank You to zmeutz For This Useful Post:
Old 01-20-2021, 22:13   #2 (permalink)
bobo bokota's Avatar
Member: 2148606
Thanks Meter: 386
Originally Posted by zmeutz View Post
Hi,
Thanks!
Stefan
I try A7
Envoyé de mon iPhone en utilisant Tapatalk
Old 01-21-2021, 11:04   #3 (permalink)
Member: 2263638
Thanks Meter: 3
Doesn’t work, tested also with DFU box c2
Old 01-22-2021, 07:54   #4 (permalink)
Member: 2148606
Thanks Meter: 386
For now iPad air 2 no longer works with SN A8 but A7 I made more than 5 pieces 3 days ago
Old 02-08-2021, 12:38   #5 (permalink)
Member: 86807
Thanks Meter: 3
Ipad mini 4 128gb A1530 A8 and A7 Serial Problem
Hi
I have ipad mini 4 32GB and 128GB with icloud lock tried with A8 serial and A7 Serial 3,4 Different serials but All the time Both Same Error unable to Active Kindly help if any body Knows Thank you
The Following User Says Thank You to mobile_tec For This Useful Post:
Old 02-08-2021, 23:49   #6 (permalink)
Member: 2148606
Thanks Meter: 386
Which 4G OR WIFI model do you have
Old 02-09-2021, 09:42   #7 (permalink)
Member: 2649893
Thanks Meter: 2
Hello, i have same problem, i try whit sn bt wmac, from ipad 1mini to ipad mini2 wifi.
error no possible contact server(error info) i try whit ipbox v2, and other. same issue//[000007F7:F0A86DF0] :-) syscfg list
Key: SrNm Value:
Key: MLB# Value: C7L405102UFFH1PA6
Key: Mod# Value: ME279
Key: Regn Value: CH/A
Key: CFG# Not Found!
Key: OPTS Value: iPad4,4/WIFI&BT/NAND,SIZE=16G/RAM,SIZE=1024M/Black
Key: SwBh Not Found!
Key: HwVr Value: 0x00000000 0x00000000 0x00000000 0x00000000
Key: PACV Not Found!
Key: MtCl Value: 0x0601504E 0x00000000 0x43324400 0x34333034 0x555A4330 0x594D4646 0x00005541 0x00000000 0x0671383B 0x0C0908F4 0x06F604E8 0x292E0A52 0x272C3224 0x3224292E 0x2A2C272C 0x2A292A2A 0x2A2A2A2A 0x29292A2A 0x2A292929 0x29292929 0x00002C29 0x00000000 0x24242426 0x24242424 0x24242424 0x24242424 0x24242424 0x26232424 0x00000000 0x1E210000 0x1E1D1E1E 0x1E1E1E1E 0x1E1D1E1E 0x1E1D1D1E 0x1D1D1D1D 0x0000201C 0x00000000 0x30303034 0x30303030 0x31303031 0x3030302F 0x30303030 0x332F302F 0x00000000 0x282B0000 0x28282828 0x29292828 0x28282929 0x28282828 0x28282828 0x00002A27 0x00000000 0x20202123 0x21212020 0x21212121 0x20202020 0x20202020 0x231F2020 0x00000000 0x01000000 0x01010101 0x00000001 0x01010100 0x00010101 0x01000000 0x02020202 0x00000001 0x01010100 0x00010101 0x01000000 0x01010101 0x00000101 0x02020200 0x00020202 0x71710000 0x72727272 0x72727272 0x72727272 0x72727272 0x72727272 0x00007172 0x00000000 0x5C5C5C5B 0x5C5D5C5C 0x5D5D5D5D 0x5D5C5D5D 0x5D5D5C5D 0x5C5C5C5C 0x00000000 0x4C4A0000 0x4C4D4C4C 0x4C4C4C4C 0x4D4D4C4C 0x4C4D4D4C 0x4D4C4D4D 0x00004B4C 0x00000000 0x86868585 0x86868686 0x86868686 0x87878686 0x86878687 0x86868786 0x00000000 0x62620000 0x63636363 0x64646363 0x64646363 0x63646464 0x63636364 0x00006363 0x00000000 0x54545453 0x55555455 0x55555555 0x55555555 0x54555455 0x54545454 0x00000000 0x05000000 0x08090908 0x00000106 0x08070400 0x00050708 0x04000000 0x07070706 0x00000005 0x0A080600 0x0207090A 0x05000000 0x08090908 0x00000206 0x08070500 0x01060808 0x02540000 0x02560255 0x0244025C 0x02500252 0x025C024B 0x02620258 0x02630256 0x02570256 0x025A025D 0x02560265 0x0268026D 0x02620258 0x02550269 0x0254025C 0x02660255 0x02580257 0x02500250 0x025A0248 0x02570256 0x02560261 0x0260024F 0x02550268 0x02500258 0x02570252 0x02550259 0x02530243 0x02590247 0x00320262 0x00180258 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x10101010 0x0B0B1010 0x0B0B0B0B 0xC7C7C7C7 0xC7C7C7C7 0xC7C7C7C7 0x00000040 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x01000000 0x1111100E 0x0D101111 0x100C0000 0x11121212 0x00000C0F 0x1313110A 0x09111313 0x0E0E0000 0x0F0F100F 0x00000D0E 0x11110F0C 0x0F0F1111 0x110B0000 0x13131313 0x00000C11 0x11C2132F 0xE6541192 0x0010FFF1 0xFFFA06ED 0xFF300007 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
Key: MtSN Value: D2C40340CZUFFMYAU
Key: AlsC Not Found!
Key: ATSc Value: 0x00000006 0x00000009 0x00000000 0x00000000 0x00000000
Key: GYTT Value: 0x23000002 0xFE71FEAC 0x240000A7 0xFE76FEB0 0x25000099 0xFE81FEB5 0x2600007F 0xFE89FEB9 0x27000064 0xFEB1FEBE 0x2800004C 0xFEDCFEC2 0x2900003C 0xFEC2FEC6 0x2A000027 0xFEDEFECA 0x2B000018 0xFEE9FECF 0x2C000008 0xFEAAFED0 0x2D00FFEC 0xFEFBFED5 0x2E00FFE7 0xFEF4FED9 0x2F00FFD2 0xFF05FEDE 0x3000FFC5 0xFF0BFEE1 0x3100FFB0 0xFF05FEE5 0x3200FF9C 0xFF00FEE7 0x3300FF8F 0xFF08FEEC 0x3400FF7A 0xFF19FEEF 0x3500FF6D 0xFF18FEEF 0x0000FF69
Key: GSCl Value: 0xFFFFEE85 0xFFFFFFD2 0x0000004B 0x0000001B 0xFFFFEDDD 0xFFFFFFFC 0xFFFFFFF1 0x00000011 0x000011E1
Key: GSCi Value: 0xFFF15AD7 0x000025BB 0x00003D4F 0xFFFFEA3E 0xFFF1E2A3 0xFFFFFCFD 0xFFFFF3D7 0x00000D9D 0x000E5203
Key: ASCl Value: 0x00000031 0x0000F3E1 0xFFFFFD5C 0xFFFF0F55 0x0000025C 0xFFFFFFBF 0xFFFFFF62 0xFFFFFF82 0xFFFF0383
Key: ASCi Value: 0x000002A3 0xFFFEEFB2 0x00000040 0x00010CB8 0x00000039 0xFFFFFD31 0xFFFFFF78 0x000000AB 0xFFFEFC72
Key: LTAO Value: 0x00010010 0x00000000 0x0000000F 0x00000026 0x00000010
Key: DClr Value: 0x00000200 0x00D7D9D8 0x00E1E4E3 0x00000000
Key: GICl Value: 0x00000001 0x000014CC 0x00000000 0x00000000
Key: WMac Value:
Key: BMac Value:
Key: EMac Value: 0x069F706C 0x0000DAE3 0x00000000 0x00000000
Key: W24G Value: 0xFED114C9 0x1583FFC6 0xFFC6FECA 0x00000000
Key: W50G Value: 0xFEDB1466 0x13CAFFC3 0xFFC5FEE6 0xFF081348 0x1410FFD5 0xFFBEFED9 0xFEF81394 0x130FFFD0 0xFFD0FEFE
Key: FG2G Not Found!
Key: RSKU Not Found!
Key: CBAT Value: 0x005804DB 0x01CD01AB 0x039C0B9E 0x07C21A12 0x00000001
Key: CPAS Not Found!
Key: WpCl Not Found!
Key: BLCl Value: 0x00000100 0x528F1C50 0x0000019D 0x00000000
Key: BLCC Not Found!
Key: BLC2 Not Found!
Key: SpCl Not Found!
Key: VBST Value: 0x00000D09 0x00000000 0x00000000 0x00000000
Key: VPBR Value: 0x00000E0E 0x00000000 0x00000000 0x00000000
Key: VbCl Not Found!
Key: M2EQ Not Found!
Key: BTTx Value: 0x3F2A4F00 0x3E3B393B 0x3D3D3D1E 0x321A403E 0x36343232
Key: GLCl Value: 0x00000100 0x00000032 0x00000000 0x00000034 0x00034000 0x34000000 0x00000000 0x0000D000 0x00000000 0x00000000 0x00000000 0x001C0000 0x07000700 0xC1C1C070 0x070701C1 0x771C71C7 0x1DD374DC 0x00000005 0x00000000 0xD0343432 0x34000D00 0x00000000 0x0000000D 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00700000 0x00000000 0x07000007 0x00700700 0x1C01C007 0x70707070 0x077771DC 0x00000005 0x00000000 0x00000032 0x03403400 0xD0034034 0x03400D00 0xD00D0034 0x03400D00 0x00D00340 0x034000D0 0x00003400 0x000000D0 0x00000000 0x1C000070 0x1C1C0700 0xC1C1C01C 0x71C77071 0x7434DD37 0x00000E04 0x00000000
Key: BTRx Value: 0x001D0002 0xFFC35812 0x0000FFE1 0x003C001E 0x0077005A 0x00180096 0xFF390150 0xFF360012 0xFFC5FF7D 0x003B0000 0x0000007A 0xFFF6FFFB 0xFFE7FFEF 0xFFCFFFDC 0xFFB0FFC1 0xFF88FF9D 0xFFBAFF72 0x0000FFDF 0x003E001C 0x00780060 0x0038009F 0xFFDDFFB6 0x001E0000 0x00640041 0x00A3007C 0x00000000 0x00000000 0x01390000 0x00000000 0x00000000 0x000E0000 0x00000153 0x00000000 0x00000000 0x0154003F 0x00000000 0x00000000 0x004E0000 0x00000134 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
Key: LCM# Value: F0Y40310CX2FJDK9GN8FGLSUE
Key: Batt Value: D86404401VFFG1WA8
Key: BCSN Not Found!
Key: BCMS Value: DNL403409DNFF9L8F
Key: FCMS Value: F0W40162BPNFNQY1S
Key: BCMB Value: 544403742A0021672D3C44FDE00000000000003221111083
Key: FCMB Value: 032251201811251181111100000000001115040106E0670105 00850000000065
Key: AICl Value: 0x00000002 0x000007C2 0x000001F4 0x00000000
Key: RSCl Not Found!
Key: MdlC Value: MoPED=0x624F9851F64E5EC2A241E24C8E048C6EAD5AF3C0
Key: ARot Value: 0x00000001 0x00000100 0x000000FF 0x00FF0000
Key: GRot Value: 0x00000001 0x000000FF 0x0000FF00 0x00010000
Key: CRot Value: 0x00000001 0x00000001 0x00000100 0x00010000
Key: BCTR Not Found!
Key: UTTF Value: PASS
Key: NoCl Not Found!
Key: W24R Value: 0x00000006 0x00000000 0x0000080C 0x00000000 0x00100F00 0x00000000 0x11120000 0x00000000 0x17000000 0x00000011 0x00000000 0x00000E15 0x00000000 0x00001500
Key: W50R Value: 0x0E000008 0x04000006 0x0F000008 0x09000005 0x0C000006 0x07000001 0x0C000007 0x0C000002
Key: WRxT Value: 0x0000000E 0x00000000 0x00000000 0x00000000
Key: CmCl Not Found!
Key: RMd# Value: A1489
Key: LSCI Value: 0x08010200 0x3FF80048 0x40010100 0x00000001 0x019000A6 0x00320064 0x006F0808 0x00010525 0x0001FFEC 0x0000747B 0x0000A3BD 0x000129DB 0x00000000 0x00000000 0x07DD07CF 0x020D020A 0x07570738 0x00000000
Key: McCl Not Found!
Key: BBSn Not Found!
Key: WBSn Not Found!
Key: GPST Not Found!
Key: CPCl Not Found!
Key: NSrN Not Found!
Key: NvSn Not Found!
Key: FSCl Not Found!
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.14700 seconds with 7 queries
