Please team I really need to know more about this tool, plz how does it job? Is it by opening the ipad and remove some components? Or is it by special hardware accessories? Plz I want to Uyo this tool but I want to know more on it ... |
i think in pakistan there is no official reseller where we buy this? also kindly tell us that is this tool can unlock iphon4,4s,5,5s,5c,6 etc... or only ipad mini? |
http://forum.gsmhosting.com/vbb/f937...ckage-2113604/ second is need watched this vedio http://forum.gsmhosting.com/vbb/11947415-post1.html |
I want to learn this miracle can remove icloud iphone 5,6 and the connection will work? |
like 16GB update to 128GB |
how about icloud removal?? also please update we need to remove the programming IC from Phone and do the job??? or with removing only we can read ??? |
Backup/Write Hard Disk Data ( supports Full Flash Reading/Writing/Erasing) this function what does it mean ? can copy data from damaged hdd and copy it to another new hdd without lost data possible ? |
You can see the video on page 1 this thread. |
HI, Why cant remove icloud from iphones if we can edit all info inside, as IMEI and other info? Didnt understand this part, can you explain. Im interested in buy the equipment but i didnt understand why i cant remove the icloud on iPhones. If i remove the NAND and change the IMEI as i remove the the CPU and read and Write the data, etc... Can you explain this part? |
Iphone is different with ipad ! If you want to remove icloud for iphone need to change 3 chip ic For ipad using ipbox v2 ... You just change SN only .... Done! |
Hi, I know that to iphone i need to change 3 chips. I thought that i can prog the chips from iphone on the IP BOX 2. Do you have similar solution for iPhone? |
up lode cler HD video explain more this box ..... no more update 1st time you now this time you support more? whats worrenty ?? |
Will make it about HD video |
this tool does not work remotely, that is, can only be removed iCloud equipment connected by cable. |
