05-01-2017, 15:14 | #18 (permalink) | |
Insane Poster Join Date: Feb 2017
Member: 2685790 Status: Offline Thanks Meter: 21 | Quote:
Post proof. Or your just bull****. Sorry to pull your trump card homie | |
11-19-2017, 19:37 | #21 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Earth and around
Member: 1442842 Status: Offline Thanks Meter: 103 | Quote:
First.. Magdani.. you are right! I will tell you a story. A customer brings a iphone 5s where he has changed the LCD Unit. After this the Power Button dont work anymore. Easy to repair normally. The customer has destoyed the buffer IC U25 physically. Ok.. But this little buffer was so hard soldered and i used a little bit higher temperature to bring it out. OK so far. I soldered a new one in and test the power button. It works.. I must tell that the customer has installed the firmware new before he brings it to me. So it was not activated. Anyway.. As i tried to install the newest firmware the phone stopped with error 9 . UFF! The the desaster beginns.. I know some error 9 are related to U2 IC.. Ok.. i changed it, but error 9 appears again. And then i switched on my brain again. What i have done? I have changed this U25. Not so far away from U25 is the power regulator U6. This one is underfilled with resin. So i removed this and reball and bring it in again. Restore endet with error 9.. Next i removed carefully the U6_RF . I know this is related to baseband and if i damage this physically this is the end of the phone. I reballed it new and bring it back again. After this the installation runs without any error and the phone is back to live again. What i want to say.. Dont start if error 9 appears to reball and reprogramm the memory. This will not work. Maybe if you heat this memory up the U6_RF is better connected after this, and it works again. But the fault was never a memory fault. A tipp if you solder in this area of U6_RF . Dont use to high temperatures! Also if you change the U6 regulator IC dont use to high temp. The U6 is very temp sensitve and will not work if you solder it in with to hot temp. | |
11-20-2017, 20:06 | #22 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Russia
Member: 1905377 Status: Offline Thanks Meter: 73 | So. My problem whith error 9 on iphone 6 solve. No rollback and no nand. No. AP31 and AR31 - this point on CPU, use PCB-layout. https://www.youtube.com/watch?v=nap0gtds5tQ |
01-08-2018, 09:43 | #23 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Gujranwala Age: 25
Member: 2451476 Status: Offline Sonork: 100.1669164 Thanks Meter: 345 | iphone 6 4013 error fix by ipbox v2 flash done after stuck on recovery iphone 6 4013 error fix by ipbox v2 flash done after stuck on recovery???? what problem |
01-24-2018, 13:16 | #24 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2751356 Status: Offline Thanks Meter: 0 | ihave 6 4013 ihave erasure now not showing 4013 but coming itunes not getting on is it important to erase boot1 boot2 if yes then should i select new file for boot1 boot 2 pease reply |
01-30-2018, 11:08 | #25 (permalink) | |
Junior Member Join Date: Nov 2017 Location: iran esf city
Member: 2780349 Status: Offline Sonork: https://t.me/tootgsm Thanks Meter: 0 | Quote:
03-19-2018, 11:43 | #26 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: in your heart Age: 37
Member: 557167 Status: Offline Sonork: 100.1626163 Thanks Meter: 12 | Quote:
2day i done iphone 6 with this method THNX TO MUCH | |
