11-05-2017, 05:45 | #91 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: San Luis Potosi, Mexico
Member: 2109200 Status: Offline Thanks Meter: 40 | Quote:
Fools? Nand programmers are not really intended for icloud removal hahahah— you are the idiot here if you think it is just for Icloud . BR Sent from my iPhone using Tapatalk | |
11-06-2017, 15:52 | #92 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2001933 Status: Offline Thanks Meter: 2 | If I put iphone 5s nand, bb and cpu from iCloud free board to iCloud locked board will have some conflicts? iCloud free board have problem with some resistor and display is black. I don’t know who’s “serviced” the board before and I think it will be better to put on good not damaged board. It’s possible like I think? Or need something else? Sent from my iPhone using Tapatalk |
11-10-2017, 22:03 | #93 (permalink) |
Crazy Poster Join Date: Mar 2017
Member: 2697189 Status: Offline Thanks Meter: 37 | this is easy to test by fitting a genuine locked nand of course but should not work a UDID is a SHAH1 hash of serial, wifi,btooth and ecid as a string. the latter is not stored in nand! This is an encryption problem. it activation lock no longer uses serial only the authentication with apple server is essentially looking at cpu key the on disk encryption uses the same key i believe. |
11-11-2017, 13:48 | #94 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1872250 Status: Offline Thanks Meter: 33 | im looking for someone who can unbound the mac address on iphone 6s plus the device now is on ios 10.2 i know if it will be updated it will cant activate but its better to fix it because actualy without wifi still cant activate on ios 11 so i will stop the ota update and the device will working im preffer some guy in europe im in Greece please send me pm with price |
11-26-2017, 09:45 | #99 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
Yes, you can upgrade NAND Try to send one back to china and see if it will get there. it will be confiscated. | |
12-11-2017, 10:58 | #101 (permalink) |
Insane Poster Join Date: Sep 2011
Member: 1658652 Status: Offline Thanks Meter: 9 | on ios 11 it is not possible for ipads to bypass icloud. The only way i think you can bypass is using hardware method first and than using some software to bypass it. i m not too sure this is just my assumptions. |
12-29-2017, 18:33 | #103 (permalink) |
Insane Poster Join Date: Mar 2010
Member: 1252523 Status: Offline Sonork: 100.1617870 Thanks Meter: 8 | Hello Now i have big problem after repair error 4013 with ip box i'm stuck in activation ios 11 i have payed for the check gsx Bluetooth address but gsx have saved my fake address generated with ipbox do u know any solution or how to find for the get old and good wifi address |
