Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > IP-BOX (The SMART Tool)
Old 07-22-2017, 14:06   #1 (permalink)
Member: 64823
Thanks Meter: 439
iPad mini 2 - Change SN - Blank Screen after BOOT
After changing the SN when flash the iPad it FULL flash but after activation screen BLANK and itunes write:
" there is a problem with your iPad "
THe iPad flash successfully flash but after apple LOGO the screen went BLANK !! itunes detect the iPad in Normal mode but it writes: " there is a problem with your iPad "
The Following User Says Thank You to zakiyyboss For This Useful Post:
Old 07-22-2017, 20:18   #2 (permalink)
Member: 2558205
Thanks Meter: 8
boss , check boot information again with box maybe the box not write SN information
The Following User Says Thank You to balaawi6 For This Useful Post:
Old 07-27-2017, 11:28   #3 (permalink)
Member: 64823
Thanks Meter: 439
Bro i Double chedk I remove again and i did:
Erase ALL
Write NEw serial
FIX SN
Check SN
rebuild and FLASH again
Old 07-27-2017, 12:08   #4 (permalink)
Member: 64823
Thanks Meter: 439
Now after flash with iTunes and get the ERROR above that is " there is a problem with your iPad " i remove again EMMC and connect again !! Try to EXTRATION DISK DATA getting error below.. Am i doing something wrong????
Page generated in 0.13981 seconds with 8 queries
